What Is This --- Read GDFS------------------------------------------------------------------ User selected phone W200 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 355405-01-509210-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... \ Error : Loader failed to dump GDFS. Hint : Power on the phone and change settings/contacts/theme e.t.c. Hint : This will reorganize GDFS structure and possibly fix the error. Error : Failed. and phone not. power :mad: |
what VERSION u use if latest try try unlock again same error Flash phone same firmware BR |
If you try any pin, you will see same result... Only clean the area carefully... |
flahe the phone with dream box, files main and fs.. but not power the phone... |
NOTE: same firmware |
v0.914028/UNI CARD SERIAL: 00055218 Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35540501509210 CERT:RED FLASH CID:52 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35540601471892 Model:W200a MAPP CXC article: R4GB001 prgCXC1250719_GENERIC_ME MAPP CXC version: R4GB001 Language Package:AMERICA_2 CDA article: CDA102738/310 CDA version: R3A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4GB001_CXC1250719_GENERIC_ME" YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK Elapsed: 3 secs. .... what should make |
flashe the phone with setool box, but continue similar... its is the "read phone info" in normal mode with dream box. --- Reading Info--------------------------------------------------------------- User selected phone W200 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 355405-01-509210-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 GDFS Simlocks : Lock 0 = OFF (00) [5/5] (Network) Lock 1 = OFF (00) [5/5] (Network Subset) Lock 2 = OFF (00) [5/5] (Service Provider) Lock 3 = OFF (00) [5/5] (Corporate) Lock 4 = OFF (00) [5/5] (SIM Card) Lock 5 = OFF (00) [5/5] (Extended) Operator code = 000-00 Done. it is the log of operations --- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 355405-01-509210-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... \ Error : Loader failed to dump GDFS. Hint : Power on the phone and change settings/contacts/theme e.t.c. Hint : This will reorganize GDFS structure and possibly fix the error. Error : Failed. and phone not power on, not be make.. help me and light of infrared blink... |
BR |
DREAM BOX TEAM. help please... BR |
bro and attempted write other GDFS and unlock, but sample the same message. Hint : Now the probe might be disconnected Processing ... \ Error : Loader failed to dump GDFS. Hint : Power on the phone and change settings/contacts/theme e.t.c. Hint : This will reorganize GDFS structure and possibly fix the error. Error : Failed. |
I Had The Same Problem I Tried To Repair It With Dream Box But No Success Then I Changed The Flash Ic And Did It If Any Method Should Be Discussed |
This Is The Problem With The New Version?????... Br |
No... maybe you wrote a GDFS or FULLFLASH from a "DreamBox unlocked" phone in a non "Security Bypassed" phone. Your EROM is not "DreamBox modified EROM", then it checks security areas at boot. DreamBox unlock remove this areas, because that Dreambox modified EROM that is writen in "Stage 1/2" don't verify security areas, but original EROM checks(phone not entered in security bypass). Can you boot pressing C and using DCU-60? If yes, flash and customize it by SETOOL using DCU-60 and retry the "Security Bypass" procedure. If no, you need to restore original GDFS. Try to select "Normal" boot mode to restore a previously made GDFS backup from this phone. If you made backup using SETOOL, restore with it. But if you made backup using DreamBox and can't restore it, you will need another W300 CID52, but this "Security Bypassed". Backup GDFS from W300 working phone using SETOOL. Write the DB GDFS backup of dead phone in good security bypassed phone using security bypass mode. after, backup GDFS from "good phone" (that now have dead phone GDFS) with SETOOL and restore this GDFS to dead phone. Your phone will live again, but you need to flash MAIN+RAW_FS using DCU-60 by SETOOL to do Security Bypass on DreamBox. Don't forget to restore GDFS backuped from the good phone using SETOOL. If you don't have any backup from GDFS, you need wait for a new update. Procedure tested by me and works good. |
