Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 10-25-2005, 20:43   #1 (permalink)
kasner's Avatar
Member: 56469
Thanks Meter: 136
Can't connect UFS when other FTDI interfaces connected
Can't connect UFS when other FTDI interfaces (Martech, Vygis or JAF)connected. Can You fix it?
ThanX
BR Kasner
Old 10-25-2005, 20:58   #2 (permalink)
Member: 59969
Thanks Meter: 13
Just install new drivers(comes with UFS suite 2.(1).1 and change usb cable. Also can be problem if u have bad power supply on MB...
Old 10-25-2005, 22:09   #3 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 60
Just make sure you dont use a usb hub, unless it is powered or you will experience no-end of problems!!!
WBR
yeldar
Old 10-25-2005, 22:39   #4 (permalink)
Cheater -Don't Deal with him-
.:GSM International:.'s Avatar
Member: 8879
Sonork: 100.84016
Thanks Meter: 327
Soy guys, dont agree! Have tried all of what you have said, and still no joy!
I have completely uninstalled/reinstalled twister with hwk, and used different usb lead, i also have tried it with Usb Smart plugged directly into twister, and into my usb ports, no joy.....
Please fix Zulea
Old 10-25-2005, 22:57   #5 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 60
With reference to your problem Jay, I still say it is conflict error on pc with usb and something else you have installed mate!
I have sold 300 of these dongles since launch and not really had any other problems from customers with excatly the same problems that you are experiencing!!
I just phoned a friend about this problem and he asked me to ask you to provide details of your pc and is the usb port you are using connected directly to motherboard or through its own hub??
Email it over to me and I will speak with him tomorrow
Enjoy your schmoke
WBR
yeldar
Old 10-25-2005, 23:00   #6 (permalink)
Member: 8879
Sonork: 100.84016
Thanks Meter: 327
hi dude
ok, its an athlon 2600 processor, and ive tried runnig usb smart though a hub, directly into my usb ports, and through twister itself....ive got it installed now, it just errors when trying to connect to ufs/twister....btw, i was only able to install usb smart AFTER installing Vygis update dongle....
Old 10-25-2005, 23:04   #7 (permalink)
Member: 8879
Sonork: 100.84016
Thanks Meter: 327
oops, sorry, that was meant to be in email, sorry lad, i forgot
Old 10-25-2005, 23:07   #8 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 60
lol - was it a bought system or made up??
Can you provide other details of this system for me please??
Cheers bro
Daz
Old 10-26-2005, 09:44   #9 (permalink)
Member: 8879
Sonork: 100.84016
Thanks Meter: 327
what other details do u need mate?
Its a amd 2600 athlon, 1gb ram, 160gb hdd, i have vygis sc, twister (with HWK), jaf, tst, nsdongle, sagem dd, usb smart, furious 2, griffin, Smart Moto and loads of other bits and pieces installed!
I have tested my twister box on my laptop, and that connects fine with usb smart....also, my leads dont work, ive never had them work since i got them! The drivers are installed, but they dont do jack....
If you need anymore info mate then text me
Cheers fella
Jay
Old 10-26-2005, 16:04   #10 (permalink)
Charly's Avatar
Member: 2008
Thanks Meter: 4
Jay I think Daz want to know things like what Motherboard and Chipset and USB contoller sh!t like that.
Regards
Charlie
Old 10-26-2005, 16:53   #11 (permalink)
senkron24's Avatar
Member: 15880
Sonork: 100.1612155
Thanks Meter: 452
you can slove esy fix you problem
your problem with ufs box have problem you can slove so
1.open UFS_Maintenance_v20
2.clik conekt buton
3.no clik (use licens database )
4. and calculate you serial with string code calculator then clik buton
active lisens and write you fria lisans in to then is all ok
and wrok grate
ps: when not wrok chanege seril and try 1.2.3.4.
wok 100%100000000000
best regarts senkron24
Old 10-26-2005, 16:57   #12 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 324
Check driver installation info file.check if they all have same vid and pid ie.
vendor id and product id.
Old 10-26-2005, 17:03   #13 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 324
vendor id and product is.
Code for 2 FTDI Devices Connected platforms GSM Programming & Reverse Engineering 3 03-07-2010 19:37
No interface connected please select interface and connect first ! lohan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 12-14-2009 06:04
6620 can't connect ufs iolejoi WD2 & APE (Symbian Phones) 4 11-30-2006 15:58
HELP! when connect UFS-3 Blue with Hwk with UFS Suite 3.0 mk21 UFS2 + UFS3-Tornadoflasher 0 08-22-2006 11:32
Page generated in 0.18530 seconds with 9 queries
