GSMSERVER GSM Shop
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 06-23-2006, 16:01   #1 (permalink)
Member: 240263
I Flash W550 B with 8.6 version but i geting following error
Switch phone ON
Get phone info
Flash CID: 49
Phone KEY: A1_DB2010_49_BROWN
OTP CID: 49
Phone IMEI: 35744200531909
Flash ID: 890D
Switch phone ON
Write Flashloader CID49
ERROR: 300414
Old 06-23-2006, 17:03   #2 (permalink)
Member: 294422
Tri this...........
1. - Use Test Point - Checked
- Skip TP when flash MAIN, FS - NOT Checked
- Complete phone after flash - NOT Checked
- Recover Certificate - NOT Checked
- Flash W550_EROM_CID49_RED.mbn as MAIN file
- Connect/disconnect Test Point on phone when software ask
2. - Use Test Point - Checked
- Flash (your choice) MAIN file from MAIN_IMEI directory
3. - Use Test Point - Checked
- Skip TP when flash MAIN, FS - Checked
- Flash (your choice) FS file from FS directory
- Not need to use Test Point on phone
4. - Use Test Point - Checked
- Flash W550_EEPROM_Area_Flash.mbn as MAIN file
5. - Use Test Point - Checked
- Complete phone after flash - Checked
- Remove all filenames from MAIN and FS edit boxes
6. - Use Test Point - Checked
- On Repair tab mark Rebuild SP Area and Remake CRC's
- Do Selected Jobs
7. - Use Test Point - Checked
- On Unlock tab mark Clear SP Locks
- Do Selected Jobs
Thanks to Zulea.
Old 06-23-2006, 19:17   #3 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
i am sucssesfully flashed many w550 b with above procedure thanks goes to zulea
Old 06-26-2006, 13:58   #4 (permalink)
Member: 240263
ok i am sucssesfully. thanks goes to zulea.
Old 06-28-2006, 08:51   #5 (permalink)
Artangel's Avatar
Member: 20970
Thanks Meter: 14
how about this problem?
history: White Screen...
i tried to Flash MCU, FS and it was successful but when Complete phone after flashing this problem occurs...
Waiting to finish Switch phone ON
Start Flashloader CID49
Reading flash CXC version
Version: R4AB048_CXC1250086_CHINA_EL
Send FLASH application
Recover first flash part
Send FS application
ERROR: 30303A
sorry for my bad english.. wakekek!
thanks in advance!
Old 06-28-2006, 14:19   #6 (permalink)
Crazy Poster
Member: 178065
thanks in advance!
its your gdfs, pls write gdfs then do unlock then try complete fone, if still no luck then flash main and fs with complete fone checked but this time use different firmware (latest firmware).
Old 07-10-2006, 15:46   #7 (permalink)
piracik's Avatar
Member: 133762
Thanks Meter: 242
my same as #1 post
Switch phone ON
Get phone info
Flash CID: 49
OTP CID: 49
Phone IMEI: 357xxxxxxxx
Flash ID: 890D
Switch phone ON
ERROR: 300414
phones powers on itself
there are three TP - which i use and where connect it - when im using TP on different point error 300312 (thin im not connected to GND)
MAIN + FS + 8.6 not working why? as i read it should work
plz answer
k 200i hang with 3,6 volt,but with 4,1 volt ok give me solution pian_aneurysm Sony Ericsson Hardware Repair 0 05-31-2009 15:42
need nspro 3.8.6 version ahmed14 NSPRO 5 07-12-2008 13:15
W550 can't flash with 8.6 paklink SonyEricsson (USB-Smart) 4 06-20-2006 14:43
Try to Flash 3310 5.87 to 6.33 but there problem pls help me Galgu Nokia Hardware & Hardware Repair 6 03-20-2005 10:32
Flash T610 R3C002 with Terminator 6.4? eason_c Sony Ericsson 4 10-17-2003 17:39
Page generated in 0.31660 seconds with 8 queries
