Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 09-02-2006, 09:41   #1 (permalink)
Member: 200647
J220 not connecting in USB-Smart
I have a j220i and i am trying to read the codes with USB- Smart. I use SEMC-Tool 8.7 and i am getting the error : Phone not powerd up. i have remove the battery, put the cable, pres do job, put batery back but nothing. Any solution please?
br,
calin
Old 09-02-2006, 10:26   #2 (permalink)
KelvinShadow's Avatar
Member: 178726
Thanks Meter: 69
br,
calin
With USB-Smart it's very hard to get the phone in test-mode. If you use UFS use UFS ATRz to unlock it. Direct unlock not possible, manual unlock. (Not accepted simcard, press '*', 'left', 'left', '*')
If not using UFS, best with fully charged battery. Keep trying with power button. It's hard but, if you lucky you will get him in test-mode. So USB-Smart can read codes.
Good luck with it.
Kelvin
Old 09-02-2006, 10:40   #3 (permalink)
Member: 200647
I have UFS but i can't use J220 (it is grey) in the phone list. And i don't have cable for it from UFS. Can i use the cable from USB Smart (Fitgher). And what should i try? Init Simlock?
thanks very much
calin
Old 09-02-2006, 10:54   #4 (permalink)
Member: 178726
Thanks Meter: 69
thanks very much
calin
You can try to use that cable, but if you can't select the phone. You still can't not use UFS. If it's a rj45 cable there is the possiblity that it work, but use info first, if info OK then it's the same cable.
Or you have to instal HWK Killer, use search option to find the installer.
Succes!
Kelvin
Old 09-02-2006, 11:12   #5 (permalink)
Member: 200647
I have maneged to install hwk killer but i don't see any info button in UFS ATRz. What option shoul i try? I have buyed it a couple of days ago and i haven't managed to lear every thing.
thanks a lot
br,
calin
Old 09-02-2006, 11:17   #6 (permalink)
Member: 178726
Thanks Meter: 69
thanks a lot
br,
calin
Choose model J220i press go.. If phone boats and so phone info, then you can 'init locks'.
Kelvin
Old 09-02-2006, 11:30   #7 (permalink)
Member: 200647
No it's not working . I think the cable it's not good. It is a rj45 but i don't know if it has the same pinout as the hwk cable. I will search for the pinout and try to modify it,
Thanks alot
calin
Old 09-06-2006, 16:47   #8 (permalink)
Member: 57254
Thanks Meter: 7
I have 2 pieces at same time. One unlocked without problems with USB SMART. Second one can NOT connect to the USB SMART nor CRUISER. I used twister and fighter cable as interface. Can't explain !!!
W810 Cann't Make Connection With USB-Smart Afzaal Sony Ericsson 10 05-25-2007 07:24
K608i Cant Connect to USB-Smart or...... thcoms Sony Ericsson 11 10-10-2006 20:35
C975 Not Connected In Smart Clip zonetrichur Smart-Clip 5 09-24-2006 16:35
interface, 4-in-1 option missing in usb smart s.e sallu SonyEricsson (USB-Smart) 3 07-02-2006 00:36
D750i not listed in usb smart! loneunlocker SonyEricsson (USB-Smart) 5 05-17-2006 15:42
Page generated in 0.14760 seconds with 9 queries
