Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 04-13-2006, 09:13   #1 (permalink)
Member: 193369
K608i dead after READ !
Hi, i have a k608i, CID 49.
Today i tried to READ firmware with 7.1 soft version.
I have cruiser 4-1 cable working ok (i used it a lot of time, also for free k608 using Tp and setool)
I made only read and have this log :
Switch phone ON
Get phone info
Flash CID: 49
Phone KEY: A1_DB2000_49_RED
OTP CID: 49
Phone IMEI: 3568410XXXXXX
Flash ID: 200D
Switch phone ON
Write Flashloader CID49
Waiting to finish
Switch phone ON
Send FLASH application
Read MAIN to file: "test.mbn"
ERROR: 302414
Now phone simply doesn't start at all !!!
Why and how is it possible to fix it without TP ?
Thanks !
Old 04-13-2006, 09:20   #2 (permalink)
Member: 193369
I just tried rebuild SP and have this log.
Phone always DEAD at all !
Switch phone ON
Get phone info
Flash CID: 49
OTP CID: 49
Phone IMEI: 35684100XXXXX
Flash ID: 200D
Switch phone ON
Waiting to finish
Switch phone ON
Write GDFS Flashloader
Switch phone ON
Start GDFS Flashloader
Rebuild SP area and CRCs
Switch phone ON
Waiting to finish
Switch phone ON
Reading flash CXC version
Version: R2M001_CXC1250077_EU_5_MI
Recover first flash part
ERROR: CXC version not supported for recovery!
Old 04-13-2006, 09:23   #3 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 102
yes...same trouble for me....
Old 04-13-2006, 09:24   #4 (permalink)
SALNAI's Avatar
Member: 43478
Thanks Meter: 33
have you tray to connect it with TP ,,or just with cable ?
ok for the CID49 ,,i think that you have solder the TP ,,so your problem is in the tp resistor ,,you must change it ,,or resolder it correctly ,,,and inch***** ,,all will work correctly
good luck and best regards from SaLnAi
Old 04-13-2006, 09:26   #5 (permalink)
Member: 193369
I think version of firmware NOT tested...
And the problem is now that the phone is not working also for charge battery !
I have to take another k608 and charge battery in this way....
Old 04-13-2006, 09:28   #6 (permalink)
Member: 193369
NO TP soldering or similar !!
Only cable...
So no hardware error for sure...i have not open phone at all !
Old 04-13-2006, 09:28   #7 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 102
yes..I recive 5 phone....2 work with testpoint....yesterday but today I try without testpoint..and one phone is now in PLEASE WAITING....and second is dead after READ function....and the last is without software intervention...
Old 04-13-2006, 09:32   #8 (permalink)
Member: 193369
I made an other k608 with TP and "old free setool2" without problem.
Also flash it with k600 firmware and all ok !
Today try only READ with semc7.1 and kill one...
May be i'll take again "old setool2" and with TP flash it with k600 firmware
But i hope to have a solution without TP and have to open it !
Old 04-13-2006, 09:36   #9 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 102
please try and post the result here!!!
Old 04-13-2006, 09:44   #10 (permalink)
Member: 193369
I wait a little to see if it's possible to fix WITHOUT TP...
I don't like too much to open k608i....
Old 04-13-2006, 10:19   #11 (permalink)
oldsindbad's Avatar
Member: 17189
Thanks Meter: 66
guys
I need flash files that is for K608
I know it is the same as K600
but my *******r wants his k608 back as he thinks it is better
so
I do have the full flash of repair for the K608
does that file include the file system 2
or what shall I do ??
thanx in advance
Old 04-13-2006, 10:23   #12 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 102
so
thanx in advance
Man....your post is incomplet...
Do you have usb-smart? if yes..go to support...all files is in support area...
What is Cid for your phone....?
This post is for dead phone after read with usb-smart...
Old 04-13-2006, 10:28   #13 (permalink)
oldsindbad's Avatar
Member: 17189
Thanks Meter: 66
sorry Mr
well
1. I am posting here coz I have a usb smart
2. In the support area there is no files for K608=k600+8
3. I know it for the dead bla bla bla
4. My dead phone is alive but after reflash and 2 K600 = k608-8
5. CID 49 ofcourse was the phone (and the flash files needed at any CID even CID 1)
b4 complaining check the support area and see for urself
happy new year
Old 04-13-2006, 10:41   #14 (permalink)
Member: 193369
Also tried to flash recovery firmware...
No good idea...
Always the same...
May be better to use old setool2 and TP for flashing good K600 firmware...
Switch phone ON
Get phone info
Flash CID: 49
OTP CID: 49
Flash ID: 200D
Switch phone ON
Waiting to finish
Switch phone ON
Send MAIN flash file: "K600_CID49_R2F015_FullRepairFlash.mbn"
ERROR: 30223B
Old 04-13-2006, 10:43   #15 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 102
K...
what is the diference beetwin one k600 and k608 ..both with original firmware?
I don't know, because I haven't one k600...
The Following User Says Thank You to DomnulV For This Useful Post:
SE K608i dead after unlock Naseerjako MT-BOX 7 05-17-2006 15:44
k608i dead after unlock without tp basim Sony Ericsson 5 03-24-2006 15:44
K608i Dead After repairing certificate Naresh Cruiser Suite 17 02-01-2006 11:56
k608i dead after unlock SIXTUS Sony Ericsson 2 11-30-2005 07:47
k608i dead after unlocking & cid changing adam92se Sony Ericsson 2 11-27-2005 17:05
Page generated in 0.20058 seconds with 10 queries
