Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 05-22-2006, 13:33   #1 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
w550i error
hi,
phone IMEI: hone IMEI: 35744300xxxxxxx
Flash ID: 890D
Switch phone ON
Write Flashloader CID49
Waiting to finish
Switch phone ON
Start Flashloader CID49
Send FLASH application
Checking MAIN flash file
Send MAIN flash file: "W550_R4CB020_ZONE1_STANDARD.mbc"
MAIN flash sent OK
Checking FS flash file
Send FS flash file: "W550_R4CB020_EU5.fbc"
ERROR: 30223B
Flash ID: 890D
Switch phone ON
Waiting to finish
Switch phone ON
MAIN flash sent OK
ERROR: 30223B
want help abt this error.
wbr
Old 05-22-2006, 14:29   #2 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
make sure that the fone battery is charged.
Old 05-22-2006, 14:50   #3 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
thanks stylo,
i have use fully charged battery. but just i have open phone and see there is charging diod is burnt. now i remove diod and check again.
thanks for reply.
wbr
Old 05-22-2006, 16:38   #4 (permalink)
vertz's Avatar
Member: 173878
Thanks Meter: 295
Zulea made a little tutorial on how to flash w550. have you tried it, here it is
Here is guide how to full repair W550
Usualy with this procedure can be solved ANY software problems
(dead, Please Wait, ...)
1. - Use Test Point - Checked
- Skip TP when flash MAIN, FS - NOT Checked
- Complete phone after flash - NOT Checked
- Recover Certificate - NOT Checked
- Flash W550_EROM_CID49_RED.mbn as MAIN file
- Connect/disconnect Test Point on phone when software ask
2. - Use Test Point - Checked
- Flash (your choice) MAIN file from MAIN_IMEI directory
3. - Use Test Point - Checked
- Skip TP when flash MAIN, FS - Checked
- Flash (your choice) FS file from FS directory
- Not need to use Test Point on phone
4. - Use Test Point - Checked
- Flash W550_EEPROM_Area_Flash.mbn as MAIN file
5. - Use Test Point - Checked
- Complete phone after flash - Checked
- Remove all filenames from MAIN and FS edit boxes
6. - Use Test Point - Checked
- On Repair tab mark Rebuild SP Area and Remake CRC's
- Do Selected Jobs
7. - Use Test Point - Checked
- On Unlock tab mark Clear SP Locks
- Do Selected Jobs
w550i error please waite fateh76dz SonyEricsson (USB-Smart) 1 04-17-2006 07:34
Zulea W550i Error Wid 7.1 **RAJESH** SonyEricsson (USB-Smart) 2 04-13-2006 13:44
W550i error massage gsm_boy Cruiser Suite 2 02-28-2006 16:32
W550i error buffer Cruiser Suite 1 02-27-2006 05:18
w550i error vish_thakkar786 Cruiser Suite 1 11-29-2005 16:31
Page generated in 0.17209 seconds with 9 queries
