Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 12-30-2008, 06:34   #1 (permalink)
Member: 485737
Thanks Meter: 5
k800i joystick diode help!!!
all diodes for joystick of k800i are defective,what should i do???do ineed to remove the 5diodes around the joystick and make a jumper.or replace it and where ican get that diodes,my unit is water damage.urgent....
The Following User Says Thank You to al_boom37 For This Useful Post:
Old 12-30-2008, 06:43   #2 (permalink)
Member: 598454
Thanks Meter: 274
make jumppers joystiick works ok
The Following User Says Thank You to talatmehmood For This Useful Post:
Old 12-30-2008, 06:47   #3 (permalink)
Member: 485737
Thanks Meter: 5
sir but all diodes for jumper are defective,i tried to make a jumper but still no work,is it ok if i remove all the diodes for joystick and make a jumper?
Old 12-30-2008, 07:05   #4 (permalink)
Member: 598454
Thanks Meter: 274
i think its ok as u can remove diodes from k750 and it works ok if for k800 not works then u can use from k750
Old 01-07-2009, 04:33   #5 (permalink)
Member: 485737
Thanks Meter: 5
problem solved,i took small diodes from different unit.tnx to talatmehmood
K800i Joystick Problem...Firmware? hi_chris Sony Ericsson Hardware Repair 4 08-27-2010 14:41
K800i joystick ways plzzzzzz dapinderjit Sony Ericsson Hardware Repair 3 11-26-2009 05:20
k750 joystick diods ansari123 Sony Ericsson Hardware Repair 11 08-19-2009 03:26
k800i joystick ways ..:::Gsm india:::.. Sony Ericsson Hardware Repair 3 02-28-2009 17:42
replacing a k800i joystick switch? Help? Please? I'm a girl... lol kayf Sony Ericsson Hardware Repair 5 06-29-2008 18:06
Page generated in 0.14395 seconds with 9 queries
