Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 09-09-2005, 14:26   #1 (permalink)
Member: 146722
Thanks Meter: 3
Question t610 and other SE phones cannot unlock via t28 datacable.
t610 and other SE phones cannot connect via t28 datacable.
always error|:
Connect to phone
Check if RSA is active
Bypass boot authority
ERROR: 0001A1
Old 09-09-2005, 14:29   #2 (permalink)
::.::SOUFIZ GSM::.::'s Avatar
Member: 59209
Thanks Meter: 19
hehehe try to boot it using on off bottom = power botton all will be ok
Old 09-09-2005, 15:11   #3 (permalink)
*phone-company*'s Avatar
Member: 60001
Sonork: 100.106474
Thanks Meter: 151
yes right....works perfect....all 2 sec press powerbutton short time until boot beginn
Old 09-09-2005, 15:15   #4 (permalink)
fanbang's Avatar
Member: 73674
Thanks Meter: 91
try clean the cable and phone contacts as well
Old 09-09-2005, 15:35   #5 (permalink)
Member: 146722
Thanks Meter: 3
If I didnt push power ON button I didnt get this message .
always error|:
Connect to phone
ERROR: 0001A1
with other sw works well. via com1 with datacable or universal box always this error
Old 09-09-2005, 16:11   #6 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,448
T28 cable work ONLY on new ARM based phones (K,Z, V, F, ...).
Is CLEAR written in SEMC Tool description!! Also more times written here on this forum!!
You have to get DSS-20/25 or Cruiser 4 in 1 cable.
Old 09-09-2005, 18:30   #7 (permalink)
Member: 175224
@zulea:
here is my test with a 4in1 cable and a T630 after unlock & debranding:
(AVR ist not a problem)
Connect to phone
Initialize boot
Load data for flash
Upload ARM: "T630_Modem_Standard_R7A011.arm"
ERROR: 003608
i don't no, what is the problem ?!
"gsm-solutions" say the cable is the problem or a other tool has changed RSA-protect ... i have never use a other tool !!!
"gsm-solutions" has verified this problem, and only this problem when RSA=
unlocked, when RSA=locked - then is a flash not a problem !
now the question, can you make a option in semctool aka RSA=unlock / RSA=lock ???
... any idea's ?
yes, i can buy a DIV, and then make a flash - hmm, i'am will use
one tool aka usb-smart ... not more !
Thank You !
Token
Old 09-09-2005, 18:51   #8 (permalink)
Gsm2Extreme's Avatar
Member: 58493
Thanks Meter: 24
it is possible with t28 serial cable, problem is you have to press the ON button about 30 times.. hehehe
Old 09-11-2005, 02:03   #9 (permalink)
shadi's Avatar
Member: 35002
Sonork: 100.98829
Thanks Meter: 167
I THINK THE PROPLEM IN THE SOFT CAUSE I TRY Cruiser 4 in 1 cable
AND IHAVE THE SAME PROPLEM
Old 09-11-2005, 04:24   #10 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
Originally Posted by Token2K
@zulea:
Connect to phone
Initialize boot
Load data for flash
ERROR: 003608
... any idea's ?
Thank You !
Token
Try to pump the power button, its work for me
Best Regards,
Ron2pet
Old 09-11-2005, 04:30   #11 (permalink)
shadi's Avatar
Member: 35002
Sonork: 100.98829
Thanks Meter: 167
Old 09-11-2005, 12:45   #12 (permalink)
Member: 136598
Thanks Meter: 3
i used standard cable that came with it it unlocks just fine, i didnt press power button i pressed go on software and then plugged in cable to phone it automaticly recodnised it.
Old 09-11-2005, 16:44   #13 (permalink)
Member: 175224
@ron2pet:
... no way ... error 3608 by arm-flash ...
... then, i must used a div with a other cable !
... i think now, the 4in1-cable is the problem with t610/630 ...
cu token
Old 09-11-2005, 17:24   #14 (permalink)
Member: 60001
Sonork: 100.106474
Thanks Meter: 151
it works always with dss25.......it will be the next buy
Old 09-11-2005, 17:39   #15 (permalink)
Member: 63961
Thanks Meter: 11
What is dss25
Is it the pinky type cable? If not Zulea Do you have a driver for the cable that came with my USB Smart? Similar to Pinky
hi pls i need the unlock code for sendo s200 and other sendo phones tiygyliar Various 1 05-26-2005 10:15
Sonyericsson T610 And Other Models Online Server !!! bahtiyar Main Sales Section 0 07-02-2003 20:12
wanted: good suplier of unlock software and kits and other mobile phone stuff PremierGSM Main Sales Section 0 08-07-2002 23:51
Page generated in 0.22143 seconds with 10 queries
