!! No Display After Flashing 750I !!! I Got Problam With Display K750 After Flashing No Display After Flash .. Any One Sloved This Problam Pls Help ... thx sunnyc www.mobilewala.com |
What firmware did u flash it with...?? Give more details so that someone can help u. BR |
hello, is it white screen or what? what gadget are you using? if usb smart, check info cid, etc.. pls flash same main+fs then complete phone! br loloph :) |
My phone is Cid 36 i Try Old & new All flash Files But still Problam in my k750i Phone Working Fine But No Display.. Sunnyc www.usb-smart.org |
U mean to say the phone is switching on but there is no display...?? If that is the case, mate just try it on hardware. BR |
hello, is the unit new or already repaired by other technician before it got into your hand? what was the problem before you flashed the unit? if software solution does not work, try replacing with a known good LCD or check whether the flex contact of the LCD is snugly fit into the board connector? it might be incorrectly placed LCD flex to the brd conn, pls check! br, loloph |
can u just explain me what do u mean by no display? wrong CID flashing or sometimes flashing with 9v battery causes please wait and nothing is coming. is it like that or what? try to flash with 3v battery and the repair flash file for k750i that u can find in the usb-smart.com support page. then check. if not working then flash again main & fs file with complete phone. |
We have had a few of these that have blank screen after flashing. Problem was solved by replacing the lcd. Try replacing lcd and see if it is now ok |
This problems can b sorted out by software itself. There r threads saying how it is to b done, only if u use the "search" button. BR |
Yes Man U r Right My Problam Sloved After Chaned Display ... But I Dont Undarstand After Flash Display Dead :( This Display Not work Any Other Phone i give Him New Display !! Any One Sloved This Problam.. |
i have problem with k750i that is no display light and no display only display is dark but keypad light and phone also working.pls help |
