Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 12-12-2005, 17:19   #1 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
PROBLEM ON K700i
1>I have problem on one K700i Whenever i switch it on it give me an EROR on the sreen as
CONFIGURATION ERROR.PLEASE CONTACT YOUR NETWORK OPERATOR OR SERVICE CENTREWhat can i do?
2>I have any K700i with the problem of 4locks close i flash it with K700-ZONE-1 STANDRAD-R2AE033 and k700-EMEA8-R2AE033 and Repair it but still 4lock can not be remove evern it you unlock it can not do what can i do?
Old 12-12-2005, 17:45   #2 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
1. check complete phone after flash click do selected job.
2. Try to flash k700_GDFS then repair it,or flash it with Main_Imei R2AE033 Standard.
Best regards,
ron2pet
Old 12-12-2005, 17:52   #3 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
1.i tried to check complete phone after flash click do selected job.But still the phone does not work it is still on the first state
2.Should i Try to flash k700_GDFS then repair it,or flash it with Main_Imei R2AE033 Standard.and change the imei or leave it the way it is?
Old 12-12-2005, 17:59   #4 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
A) Try to flash with cid 29 without check complete phone,after flash do not power on phone just flash it again with cid36 with check complete phone.
B)There are 2 method how to repair 4 closed of k700.
1.Flash with k700_Gdfs ang make it repeair.
2.Flash with Main_Imei.
No need to edit the imei.make sure that your Main_imei version and Fs is the same,if not flash also Fs.
BR,
Old 12-12-2005, 18:25   #5 (permalink)
Member: 16927
Thanks Meter: 134
1. Did you flash Main and Fs with same version??
2. Flash GDFS
br,
fingusio
Old 09-29-2009, 03:55   #6 (permalink)
Member: 1075696
Thanks Meter: 2
can u pls... help mein my k700i power swiitch not working because the lines are broken do you have anyidea how to fix my k700i problem can you give me the power switch ways pls..........................
problem on k700i and k608i arsenal Cruiser Suite 1 04-18-2006 16:31
HELP changing imei on K700i ese Sony Ericsson 3 01-16-2005 13:42
No more "Power on" on K700i... pfnuesu TOTAL MultiServer 5 12-22-2004 15:24
Operator menu on K700i Tina_sk9 Sony Ericsson 0 11-26-2004 16:18
any news on k700i anyone mob Sony Ericsson 4 09-12-2004 23:07
Page generated in 0.14112 seconds with 9 queries
