10-13-2005, 21:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: SWEDEN, Malmoe Age: 45
Member: 10228 Status: Offline Thanks Meter: 2 | Errors in USB-Smart! --------------- ERROR: 303106: You have different flash files versions…Correct this little mistake and try again --------------- ERROR: 30353B: You have tried to flash the three flash files (Main, Fs, Sfa). Flash only= TWO flash files and later if you want you can flash Sfa file in the phone only. --------------- ERROR: 300314: This Error is appears when you have a V600(maybe any phone) with CID’s mismatch. Flash Erom with CID36 from support area for that phone. Also as a suggestion flash with main and fs file after Erom for better result. --------------- ERROR: 003608, ERROR: 00360C & ERROR: 00360C: This errors where showed when the phone had the RSA killed by Twister or Terminator --------------- ERROR: 304314: This error appears when you are using flash files with CID lower than in OTP. You must use equal or higher. --------------- ERROR: 0001A1: Possibly problem due to cable with bad connection. Check the cable or buy a new one --------------- ERROR: 00A405: This problem happens when you have communication/timers problem check that the cable is working and post a thread telling the exactly error if still happening. Problem related to T100. It’s impossible to clear SP locks in this phone. --------------- ERROR: 300301: Bug found in v1.1 in Sony Ericsson z1010, support with CID16. Problem already solved --------------- ERROR: 304107 & ERROR: 304106: Recover Certificate Problems --------------- ERROR: 303002: This problem appeared when you are trying to Complete the phone alter flash. This error should be already solved. Occurred in v1.7 --------------- ERROR: 304100: This error appears when we are trying to flash a phone that’s empty. This will be solved in a short period of time. In Z1010 phones with CID16 we had this bug corrected already in v1.9 --------------- ERROR: 302403: This was a bug corrected in v3.1 so if you have seen this error download last exe. Also this error appeared in v2.0 reading flash files bug was fixed --------------- ERROR: 300314: Problem when trying to unlock V600 in v1.7/1.9 fixed on newer versions. --------------- ERROR: 003612: Use another cable T28 com cable doesn’t work in AVR phones --------------- ERROR NETWORK CONTACT: You have to Complete phone --------------- --------------- Please post your errors and explanations here so can many get help by use a simple forum search. Maybe this is a bad idea but I thought it will be handy. //Returburk |
10-13-2005, 21:20 | #3 (permalink) | |
Member: 10228 Status: Offline Thanks Meter: 2 | Quote:
10-16-2005, 06:16 | #6 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: SWEDEN
Member: 45814 Status: Offline Thanks Meter: 34 | Quote:
Br Bernie | |
10-16-2005, 06:57 | #7 (permalink) |
No Life Poster Join Date: May 2005 Location: Vietnam Age: 50
Member: 149256 Status: Offline Thanks Meter: 285 | I ask him because he said that "CRACkeD SEMC ..no errors ". Why do I have to spend my money for a cracked software???? I bought one original USB-Smart for 2 weeks, it is very cheap and work well. |
10-16-2005, 09:28 | #9 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | Thanks people, I looked in alll your messages and of course in my own experience...Even SmartBoy claims stupid things...let's forget about that. Usb-Smart v1.1 with Spanish translation and guide for Lg3g and all the Sharp3g phones is in development.Hope I will finish at the end of this week... BR PS:It will be Usb-Smart v1.1-Regards to Laser-(People can work for free mate and can help Daniel even you don't want that...) |
interface, 4-in-1 option missing in usb smart s.e | sallu | SonyEricsson (USB-Smart) | 3 | 07-02-2006 00:36 |
how can i repair this kind of error by usb smart | gsmbac | Motorola P2K (USB-Smart) | 0 | 04-19-2006 17:10 |
LG U8120 error with usb smart | cellularcity | SonyEricsson (USB-Smart) | 11 | 01-13-2006 12:44 |
LG U8120 error with usb smart dongle . | cellularman | SonyEricsson (USB-Smart) | 4 | 01-12-2006 21:41 |
Error With Usb Smart... | Cibernetic | SonyEricsson (USB-Smart) | 7 | 12-07-2005 10:08 |
