SEMC Tool v2.1 - CDA, "1E0W", revision direct edit 1 Attachment(s) Hi, SEMC Tool v2.1 is now in support area. This version allow direct edit of CDA string, "1E0W" string. Check attached photo for details where about this strings. More details about SEMC Tool v2.1 is here: http://forum.gsmhosting.com/vbb/showthread.php?t=231503 Also there is a list with CDA strings for SEMC models uploaded in support area (thanks to Mukka). Under directory "SEMC/New_ARM_SEMC_Phones/" file "CDA listings (20050828).zip" Any updates to this Excel file are welcome. Best regards, Zulea |
Zulea there is something wrong with this version. When I launch the program my pc will auto restart immediately. I think there is a bug. The previous version doesnt have this issue. Hope that you can fix it soon. Thank you. |
Also read this thread: http://forum.gsmhosting.com/vbb/showthread.php?t=236103 user IRISHCLIPS reported is now working. So, maybe is something wrong in your PC. Try on another one, or try to clean your PC. Bets is also to disable antivirus softwares. Best regards, Zulea |
Thanks :) :) :) :) |
thank you zulea, cda- and revision-editing is MUCH appreciated! :D @all more cda-strings can be found here: http://www.se-world.info/cda-strings |
@Zulea I also have this problem as soon as I start this SEMC 2.1 XP-Pro does a mini Dump and restarts Windows reports that a 3rd Party Sofware cause this problem. I think this is a USB problem maybe with certain USB chipsets mine is an Asus PC800C Motherboards and USB chipset is Intel 82801EB Universal Host Controller. Let me know if you want Technical Info from XP report Regards Charlie |
Newbie doubt: why would I need to edit the phone CDA string? |
i was going to ask that |
now, if you are given the choice to enter a cda and rev. of your choice, SEUS will automatically update with the correct langpacks when needed. a debranded phone will be _truly_ debranded. this is ofcourse only true if you enter correct cda-numbers and dont make them up as you go :D |
I agree last working Stable version was 1.5 or 1.7 SEMC has not been stable since this version upto 2.1 I have not got 1.7 so I cannot test it. @Zulea Zulea something you did on 1.9 changed the stability of the program from 1.7 so maybe this helps pinpoint the problem. Regards Charlie |
BR, LAT |
i don`t think so @ BlickBox ;) |
Hi MRXSG Have you tried the new 3.1 in support because I think Zukki Fixed the problem as it has not crashed my system yet and I have run it 20 times now. Regards Charlie Sorry I just read that you fixed it too, I have just deleted the NTportio files from 1.9 & 2.0 & 2.1 and yes now all versions work. @Zulea What the hell is this file for mate (Compatibility with XP) Regards Charlie |
