Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 09-27-2005, 08:50   #31 (permalink)
vid
Member: 1367
Sonork: 88476
Thanks Meter: 27
@Zulea,
Problem with write gdfs to K750 up to 69%,pls check it..
Old 09-27-2005, 08:59   #32 (permalink)
SM4RTBOY's Avatar
Member: 92326
Thanks Meter: 205
@Zulea
have you tested cid 37 successfull ?
HAVE YOU ACCESS TO NETWORK ?
post Result .
wbr
sm4rtboy
Old 09-27-2005, 10:47   #33 (permalink)
Member: 2951
Thanks Meter: 4
Originally Posted by vid
@Zulea,
to Zulea: i have same problem.
Old 09-27-2005, 16:24   #34 (permalink)
UAV
Member: 22608
Thanks Meter: 2
where 2 download ?
Old 09-27-2005, 16:32   #35 (permalink)
Member: 118483
or thing the EEROM is used?
Old 09-27-2005, 17:18   #36 (permalink)
Falck's Avatar
Member: 18805
Thanks Meter: 27
Originally Posted by UAV
where 2 download ?
http://usb-smart.net/support/
Use ur login and pass from dongle S/N reader.
WBR Falck
Old 09-27-2005, 20:05   #37 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,448
@Zulea,
Just use v3.2, problem solved.
Best regards,
Zulea
Old 09-28-2005, 00:12   #38 (permalink)
amarohr's Avatar
Member: 28899
Thanks Meter: 17
Smile
[QUOTE=zulea]Just use v3.2, problem solved.
v3.2 is very good
I conect USB smart in my Twister vith HWK and program recognize all.
Very fine.
Tested all operation vith K700, F500, T610 and old R600.
Without any problem.
Tested with orginal Twister cable.
Amaro
Old 09-28-2005, 05:47   #39 (permalink)
vid
Member: 1367
Sonork: 88476
Thanks Meter: 27
Tks Zulea....try it now...
Old 09-28-2005, 12:11   #40 (permalink)
Member: 118483
what use does it have the EEROM? and how debrand k608i ? tnk
Old 09-28-2005, 12:29   #41 (permalink)
vid
Member: 1367
Sonork: 88476
Thanks Meter: 27
@Zulea,
your tools is not work with empty phone(after change flash IC)???
this phone can flash with SETOOLS2,but after flash phone hang on startup.
pls check the problem...
p/s: this phone OTP CID are 15
Old 09-28-2005, 12:35   #42 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,448
@Zulea,
Sorry my tool is not for empty phones, because I have not any empty phone here. Send me empty phone and you will have update.
Best regards,
Zulea
Old 09-28-2005, 12:42   #43 (permalink)
vid
Member: 1367
Sonork: 88476
Thanks Meter: 27
if the phone(K700) is change flash IC can??
and i have empty phone for S700 you 1??
PM or Sonork (88476:t_vid)me where to send...
Old 09-30-2005, 09:24   #44 (permalink)
SM4RTBOY's Avatar
Member: 92326
Thanks Meter: 205
@zulea
i need K750_R1N035_EU1
wbr
sm4rtboy
Old 09-30-2005, 09:58   #45 (permalink)
maxijazz's Avatar
Member: 93787
Sonork: 1646397
Thanks Meter: 9
Originally Posted by SM4RTBOY
@zulea
wbr
sm4rtboy
its already on support,check it.
br;
maxijazz
SEMC Tool v5.1 - J210 flash support, J210 flash files, K608 CID49 TP zulea SonyEricsson (USB-Smart) 68 02-09-2006 18:08
Help P910i says wrong sim card after using semc tool v3.3 jeeez Sony Ericsson 6 11-04-2005 22:55
SEMC Tool v3.2 Download New Version kg2004 SonyEricsson (USB-Smart) 5 10-06-2005 19:50
SEMC Tool v2.1 - CDA, "1E0W", revision direct edit zulea SonyEricsson (USB-Smart) 14 09-26-2005 23:50
SEMC Tool v1.1 available zulea SonyEricsson (USB-Smart) 0 08-11-2005 22:26
Page generated in 0.18939 seconds with 9 queries
