Usb-Smart Its assigned to virtual com4 but when i run semc and select com4 it cant open the port, any ideas pls :confused: |
hi. i have tested all this today, it seems that you have installed the drivers wrong just uninstall all usb port driver for the cable and after that install it again. i got this problem to but after i uninstall and installed it again i got it to work. After this go in software and select all this again and if it does this again just restart the soft and test again. Br Gsmhq |
make sure you check in device manager that is com4 cause mine went in com7 |
i have check around more and after i went int to safe mode on my xp system i checked on xp uninstall task and as my suprise i saw i hade 2 fighter and 2 cruiser cable drivers installed. i uninstalled it went to standard xp system and installed again and now it's working without that message. Hope this helps :) Br Gsmhq |
usb smart driver need pls |
Same as Setool & Cruiser 4in1_all_cable_drivers |
