09-09-2005, 14:26 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: ITALY Age: 40
Member: 146722 Status: Offline Thanks Meter: 3 | t610 and other SE phones cannot unlock via t28 datacable. always error|: Connect to phone Check if RSA is active Bypass boot authority ERROR: 0001A1 |
09-09-2005, 15:35 | #5 (permalink) |
Member: 146722 Status: Offline Thanks Meter: 3 | If I didnt push power ON button I didnt get this message . always error|: Connect to phone Check if RSA is active Bypass boot authority ERROR: 0001A1 with other sw works well. via com1 with datacable or universal box always this error |
09-09-2005, 16:11 | #6 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Inside Raskal pocket Age: 54
Member: 5325 Status: Offline Thanks Meter: 8,448 | T28 cable work ONLY on new ARM based phones (K,Z, V, F, ...). Is CLEAR written in SEMC Tool description!! Also more times written here on this forum!! You have to get DSS-20/25 or Cruiser 4 in 1 cable. |
09-09-2005, 18:30 | #7 (permalink) |
Junior Member Join Date: Aug 2005
Member: 175224 Status: Offline Thanks Meter: 0 | @zulea: here is my test with a 4in1 cable and a T630 after unlock & debranding: (AVR ist not a problem) Connect to phone Check if RSA is active Bypass boot authority Initialize boot Load data for flash Upload ARM: "T630_Modem_Standard_R7A011.arm" ERROR: 003608 i don't no, what is the problem ?! "gsm-solutions" say the cable is the problem or a other tool has changed RSA-protect ... i have never use a other tool !!! "gsm-solutions" has verified this problem, and only this problem when RSA= unlocked, when RSA=locked - then is a flash not a problem ! now the question, can you make a option in semctool aka RSA=unlock / RSA=lock ??? ... any idea's ? yes, i can buy a DIV, and then make a flash - hmm, i'am will use one tool aka usb-smart ... not more ! Thank You ! Token Last edited by Token2K; 09-09-2005 at 20:13. |
09-11-2005, 02:03 | #9 (permalink) | |
No Life Poster Join Date: Jul 2003 Location: Amman Age: 41
Member: 35002 Status: Offline Sonork: 100.98829 Thanks Meter: 167 | Quote:
I THINK THE PROPLEM IN THE SOFT CAUSE I TRY Cruiser 4 in 1 cable AND IHAVE THE SAME PROPLEM | |
09-11-2005, 04:24 | #10 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Philippines
Member: 17609 Status: Offline Sonork: 100.64817 Thanks Meter: 1,694 | Quote:
Best Regards, Ron2pet | |
09-11-2005, 12:45 | #12 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 42
Member: 136598 Status: Offline Thanks Meter: 3 | i used standard cable that came with it it unlocks just fine, i didnt press power button i pressed go on software and then plugged in cable to phone it automaticly recodnised it. |
09-11-2005, 16:44 | #13 (permalink) |
Member: 175224 Status: Offline Thanks Meter: 0 | @ron2pet: ... no way ... error 3608 by arm-flash ... ... then, i must used a div with a other cable ! ... i think now, the 4in1-cable is the problem with t610/630 ... cu token |
hi pls i need the unlock code for sendo s200 and other sendo phones | tiygyliar | Various | 1 | 05-26-2005 10:15 |
Sonyericsson T610 And Other Models Online Server !!! | bahtiyar | Main Sales Section | 0 | 07-02-2003 20:12 |
wanted: good suplier of unlock software and kits and other mobile phone stuff | PremierGSM | Main Sales Section | 0 | 08-07-2002 23:51 |
