USB-Smart 6.8 with J210i I try repair J210i with this solution: Here is procedure how to repair J210 phones (this solve ANY software problems, no power up, ...) - Use SEMC Tool v6.7 (or higher version) - NOT use UFS/Twister as interface !!! (use any other cable, Cruiser, Serial, DSS) - Flash file J210_Full_Repair_Flash.arm - Disconnect phone from cable after flash - Remove battery from phone - Insert battery to phone - Connect phone to cable - object ChkCalcCrc: TCheckBox - Repair -> Remake CRC's (SCRC, DCRC1, DCRC2) - Wait phone to power up before disconnect from cable !!! - If required, read codes, put a SIM card and unlock but always errror: Press Power On to phone! Bypass boot authority Load data for flash ERROR: 00A505 |
What s your problem??? |
With Twister error: Press Power On to phone! Bypass boot authority Load data for flash Upload ARM: "J210_Full_Repair_Flash.arm" Sending Flash Part 1 ERROR: 00AD29 |
me tried flashing repair file first with cruiser then use usb smart remake crc option strange but phone alive. but when using repair file from usb always have error |
Dear Zulea is this procedure work for j200 too? I have many problem with j200 thx |
thanx, i try with cruiser. |
The way herself applied and still he uncovered the former |
Ok, i flash j210 with cruiser with repair flash and after remake crc with usb-smart, phone alive!!! all my j210 work now!!! p.s. thax 2 ricson for idea. |
When you unlock J210i with usb smart,always do this: -after unlock wait for the phone power on itself.Don't unplugged the cable.Power off manually the phone and after you can unplug the cable. If unfortunately your phone doesn't power on because you didn't follow this step,no panic,just unlock again the phone and follow steps. |
I have the same problem: Press Power On to phone! Bypass boot authority Load data for flash ERROR: 00A505 But with Cruiser -no problem with same cable and same battery!!!! |
Yes there is a problem with j210i comunication. I successfully repaired one j210 with USB_Smart 6.8 following the described procedure but it take almost 3 hours to connect phone trying with many cables various supply voltage on MAX 232, external supplay for phone (varied betwenn 3.6 ~ 4.2V) and many more but still no good comunication and after repair i have not succeed to flash phone again with desired lang, because allways phone powred on itself. Plase Zulea fix this problem. |
PLS POST J210_Full_Repair_Flash.arm HERE |
Hey!! we do not abandon each other like ZULea did? Why not just say ' i can use newer or something' because i don't see it on support site.:mad: |
