Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 08-16-2005, 17:08   #1 (permalink)
Termy's Avatar
Member: 168911
Thanks Meter: 12
USB Smart Problems ??
I have just purchased the USB Smart Tool, but whenever I try and do ANYTHING with it I get an error,,,
Switch phone ON
ERROR: Phone not power up
I am using the cable supplied (GS-AC210 FT 4in1) which I presume is the Fighter cable ?? Or do I need to select the "Cruiser 4in1" setting ??
Well actually I have tried all combinations without any luck.
I presume (hope) this dongle will unlock and flash all new SE handsets.
Could this be a faulty dongle ??
Any help would be very appreciated.
Old 08-16-2005, 17:25   #2 (permalink)
Member: 15999
If you will have faulty dongle, you will not run program :>
Did you press "power" key?..
Old 08-16-2005, 18:53   #3 (permalink)
Termy's Avatar
Member: 168911
Thanks Meter: 12
Yes m8, I run the sw, then select the job, then select the "Do Selected Jobs" tab. It then asks to power on phone, I press the phones power button, but the phone just turns on and I get the error message.
Old 08-16-2005, 19:05   #4 (permalink)
Member: 15999
Try with serial cable (T28), have to work..
Did you set baudrate and install drivers? If yes, i have not idea.
You can check cable with davinci logger (read cid/test cable).
Old 08-16-2005, 19:21   #5 (permalink)
Termy's Avatar
Member: 168911
Thanks Meter: 12
Cheers m8, I have tried with a T28 cable but not too sure if it is an unlock cable.
Oh well I will just bin it.
Many thanx m8.
Old 08-16-2005, 21:54   #6 (permalink)
Termy's Avatar
Member: 168911
Thanks Meter: 12
Anybody have any other suggestions ??
Old 08-16-2005, 22:01   #7 (permalink)
Member: 739
Did you selected right comport?
Br Gsmhq
Old 08-16-2005, 22:20   #8 (permalink)
Termy's Avatar
Member: 168911
Thanks Meter: 12
I presume so m8, as when I selected any other port I get another error saying "Cannot Open Comport xx"
I thought my Twister, J.A.F & Griffin were awkward to set up, but this thing takes first prize ??
Old 08-16-2005, 22:22   #9 (permalink)
Member: 739
have it found the usb right ? and is there any stuff on the connector on the phone like dirt or something and is the batterie fully charge ?
Br Gsmhq
Old 08-16-2005, 22:22   #10 (permalink)
Member: 136598
Thanks Meter: 3
its not aqward did you use the cables you got with it the usb com emulater that worked for me its alpashm by the way
Old 08-16-2005, 22:49   #11 (permalink)
Termy's Avatar
Member: 168911
Thanks Meter: 12
Hi m8, yes I am usint the cables that came with it, but just looked in the device manager (on laptop) and it says that the drivers are not installed for the Syncstation DSS cable ??
I have just tried to re-install them, but keep getting the error that it cannot find the drivers. When I extract the drivers out of the zip there is a folder for Win 98/ME, and a load of other files, bt nothing stating they are for XP.
Does this dongle actually work on XP ?
Old 08-16-2005, 23:23   #12 (permalink)
Termy's Avatar
Member: 168911
Thanks Meter: 12
All sorted now,,, but dont ask me how as I aint got a clue ??
But just unlocked a K750i and unlocked and flashed a K700i so it must work,,,, lol.
Old 08-17-2005, 11:10   #13 (permalink)
garch's Avatar
Member: 138305
Thanks Meter: 2
try to install the drivers ONLY when asked, after uninstalled and perfect clean system
Old 08-23-2005, 07:50   #14 (permalink)
Cheater -Don't Deal with him-
.:GSM International:.'s Avatar
Member: 8879
Sonork: 100.84016
Thanks Meter: 327
surely not? u mean to tell me i must uninstall my jaf/twister/tst and other just to et this to work???? id rather send it back if thats the case
still having trouble getting it to install, wont find usb dongle drivers, dont have .exe to install either
can someone please help
Old 08-23-2005, 08:58   #15 (permalink)
Member: 739
As i have said try to get a new one becuase it may be broke.
ok ??? hard to not understand? or hard to send back to reseller?
Br Gsmhq
my usb-smart problem angelkid Dongle Problems (USB-Smart) 1 08-10-2006 01:06
UFS and USB-smart problem gsmsikar Dongle Problems (USB-Smart) 10 05-18-2006 05:35
Usb smart problem karamusa SonyEricsson (USB-Smart) 2 12-20-2005 20:06
usb smart problem concept SonyEricsson (USB-Smart) 2 11-06-2005 19:40
s700 usb smart problem j5lep Sony Ericsson 5 10-26-2005 17:01
Page generated in 0.31426 seconds with 9 queries
