Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 12-21-2005, 13:34   #16 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
Hi All One
Thanks to USB-Smart team to put in your Software This Model and i Saying its great Job. I have about 28 Sony Ericssion W550i Full Flash And Many Unlocked it with Usb-Smart and many W550 phone is only white display. it's greatest working
all is done 100 %............
Regard
Irfan Amin
Old 12-21-2005, 14:53   #17 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
Thanks Meter: 26,411
Originally Posted by zulea
1. Flash W550_EROM_CID49_RED.mbn (as MAIN file) with:
- "Use Test Point" checked
- "Skip TP when flash MAIN, FS" not checked
- Complete not checked
- Recovery not checked
- Make testpoint on phone when software ask for that
2. Flash MAIN + FS (your langpack choice) with:
- "Skip TP when flash MAIN, FS" checked
- No need to make testpoint on phone
3. Clear all flash filenames and only check Complete with
4. Repair -> Rebuid SP Area with:
If this not helps need flash GDFS too. GDFS file will be uploaded today later on support.
is it possibleto change fone language without opening fone i mean without TP
with this step
both flash is ok but fone shows configration error on startup
wbr
Siroya
Old 12-21-2005, 16:16   #18 (permalink)
Member: 72567
Thanks Meter: 8
with this step
wbr
Siroya
You have to complete when using FS-file.
Old 12-21-2005, 17:03   #19 (permalink)
oldsindbad's Avatar
Member: 17189
Thanks Meter: 66
I will upload EEPROM_FlashArea (this is GDFS part in flash chip) soon on support (i have the file but i need to convert and test). Maybe this evening will be there.
Best regards,
Zulea
still waiting.........
thanx
Old 12-21-2005, 20:36   #20 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
then whts the use of flashing if u have to use tp after flashing
Old 12-22-2005, 15:37   #21 (permalink)
Solutions13's Avatar
Member: 5182
Sonork: 100.45409
Thanks Meter: 18
Thumbs down
hi..
Still error.
pls correct me.. Done same procedure
Error image attached
pls upload gdfs and EEprom
regards..
Old 01-05-2006, 12:06   #22 (permalink)
Member: 144350
Thanks Meter: 3
i also step by step flashing w550 but also "please wait' who can help? very thanks?when have update w550 gdfs?
Old 01-05-2006, 20:29   #23 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
hi mate.
download the gdfs usb-smart support area
and also u read ok the gdfs file and write your phone
br
abdul majid
Old 01-08-2006, 18:53   #24 (permalink)
Member: 77897
Great
hi
zulea you r GREAT
solved w550 problem "please wait" with repair guide you loaded on support site
Thanks a lot
keep up the good work
prashant
Old 06-01-2006, 06:19   #25 (permalink)
div_raj's Avatar
Member: 59732
Thanks Meter: 47
Originally Posted by dipakgt9
I repaire one white light with only complete check without flashing,thanx for this very good update ,
can u give me diagram for test point its urgent
Old 06-01-2006, 14:41   #26 (permalink)
waleed2's Avatar
Member: 85387
Thanks Meter: 78
i try to slove problem not complete after flash using tp
Old 06-01-2006, 18:04   #27 (permalink)
MadMax71's Avatar
Member: 194949
What about this?
http://forum.gsmhosting.com/vbb/showthread.php?t=300581
Old 06-05-2006, 05:28   #28 (permalink)
MR.PRESIDENT's Avatar
Member: 152821
Thanks Meter: 67
semc 8.4 works fine too,i have just flashed se w550i and its all done
Old 07-20-2009, 10:04   #29 (permalink)
Member: 717790
i have w550 its working properly but its display will hang after a while........
if any one knows its solution plz reply me........
very thank full ALL//////////
W550 flash ok bu.... aloksoni Cruiser Suite 2 04-19-2008 15:09
6681 Dead-ape Flash Changed-now Flashing Ok-but Still In Dead zone2 MT-BOX 5 12-02-2007 17:08
w550 flash ok but not power on /ARIF/ Cruiser Suite 2 10-30-2007 15:18
w810I flashed ok now phone code after89 Universalbox 0 11-27-2006 05:33
w550 & 3230 full flash ok but pc not on TechPhone Universalbox 6 04-28-2006 08:54
Page generated in 0.20195 seconds with 10 queries
