05-22-2006, 17:44 | #1 (permalink) |
No Life Poster Join Date: Jun 2003
Member: 30754 Status: Offline Thanks Meter: 9 | w600 dead |
05-22-2006, 20:21 | #3 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Bosnien Age: 43
Member: 12904 Status: Offline Sonork: 100.1576801 Thanks Meter: 409 | Here is guide how to full repair W600 Usualy with this procedure can be solved ANY software problems (dead, Please Wait, ...) 1. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash W600_EROM_CID49_RED.mbn as MAIN file - Connect/disconnect Test Point on phone when software ask 2. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash (your choice) MAIN file from MAIN_IMEI directory - Connect/disconnect Test Point on phone when software ask 3. - Use Test Point - Checked - Skip TP when flash MAIN, FS - Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash (your choice) FS file from FS directory - Not need to use Test Point on phone 4. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash W600_EEPROM_Area_Flash.mbn as MAIN file - Connect/disconnect Test Point on phone when software ask 5. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - Checked - Recover Certificate - NOT Checked - Remove all filenames from MAIN and FS edit boxes - Connect/disconnect Test Point on phone when software ask 6. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - On Repair tab mark Rebuild SP Area and Remake CRC's - Do Selected Jobs - Connect/disconnect Test Point on phone when software ask 7. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - On Unlock tab mark Clear SP Locks - Do Selected Jobs - Connect/disconnect Test Point on phone when software ask |
05-24-2006, 17:24 | #6 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 216952 Status: Offline Thanks Meter: 1 | Check version..... I read that with version 8.5 is having that problem use 8.4 and use the files in support download them and flash the phone one by one,, that should solve the problem |
05-24-2006, 17:56 | #8 (permalink) |
Member: 30754 Status: Offline Thanks Meter: 9 | here is what happens when I try to read info phone switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35744600437923 Flash ID: 890D Operation succesfull witch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35744600437923 Flash ID: 890D S and here what happens when I try to flash it switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35744600437923 Flash ID: 890D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Send FLASH application Checking MAIN flash file ERROR: File contains EROM area! This file can be flashed on CID49 only using TP! Switch phone ON Start Flashloader CID49 Reading flash CXC version Version: R7CA017_CXC1123106_NAM_2_EE Send FLASH application Recover first flash part ERROR: CXC version not supported for recovery! |
05-25-2006, 02:07 | #9 (permalink) |
Junior Member Join Date: Mar 2006
Member: 249690 Status: Offline Thanks Meter: 0 | Hi, I have a dead W600 as well. I can't get the phone to turn on. I am using USB-SMART. When I run the software it says switch phone on and after a while gives me error "phone no power up". Sounds like you have gone past this stage. Can you tell me what I might be doing wrong? Explain how you figure which com port, do you connect something to the alligator clips? And anything else that might be helpful. Thanks Champ. |
05-25-2006, 19:30 | #11 (permalink) |
Guest
Posts: n/a
Member: | for this 'ERROR: CXC version not supported for recovery!' here is stiky by zulea. next time just read all sticky, because we put it there to help you: http://forum.gsmhosting.com/vbb/showthread.php?t=288998 Best Regards, Manole PS: Report here the result |
05-26-2006, 00:22 | #12 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: New York City, USA Age: 58
Member: 56365 Status: Offline Thanks Meter: 28 | Quote:
Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35744600427*** Flash ID: 890D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Reading flash CXC version Version: R7CA017_CXC1123106_NAM_2_EE Send FLASH application Write GDFS Flashloader Switch phone ON Start GDFS Flashloader Setup GDFS Loader Clear all SP locks Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Send FLASH application Recover first flash part ERROR: CXC version not supported for recovery! Then I tried Zuleas's fix.... Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35744600427*** Flash ID: 890D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Send FLASH application Checking MAIN flash file Send MAIN flash file: "W600_R7CA017_NAM_1.mbn" MAIN flash sent OK Checking FS flash file Send FS flash file: "W600_R7CA017_AMERICA_2.fbn" FS flash sent OK Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35744600427*** Flash ID: 890D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Reading flash CXC version Version: R7CA017_CXC1123106_NAM_1_EE Send FLASH application Recover first flash part Send FS application Start FS services ERROR: 303105 Am I doing something wrong? Now I have 2 dead phones. What's next? Too many people killing w600i phones, this can't be a coincidence. Zulea please look into this matter. As we can't always flash=40 minutes if not successfull another 40 minutes an so on. Every now and then is ok and expected but back to back to back w600i is very frustrating. Regards, JOHNNY. | |
05-26-2006, 11:51 | #13 (permalink) |
Freak Poster Join Date: Jun 2002 Age: 48
Member: 13329 Status: Offline Thanks Meter: 15 | I was having the same problem, what I did was used old 7.8 and phone came back up. I always keep old versions in my HD for this matter. Try it,you don't loose anything. |
05-26-2006, 16:13 | #14 (permalink) | |
Member: 30754 Status: Offline Thanks Meter: 9 | Quote:
as seen on this site te color orange is going dead and the color gray is doing unlock fine I don't know different yet when I get phones I will post , but is it wise read flash from that phone and flash it to orange ones? ,also that orange coming dead from people trying to unlock from Criuser , Setool and all others method | |
Genie dead no power on... [ANSWERED] | lchico | Genie Universal | 1 | 03-29-2010 07:18 |
w600 dead after flash | squall82 | Sony Ericsson Hardware Repair | 5 | 12-15-2006 08:41 |
W600 Dead | ExTrEmE99 | SonyEricsson (USB-Smart) | 3 | 09-04-2006 06:58 |
w600 dead | paklink | SonyEricsson (USB-Smart) | 5 | 08-24-2006 00:27 |
W600 Dead after unlock | Blitzkrieg_Hop | Cruiser Suite | 4 | 05-11-2006 16:03 |
