09-02-2006, 09:41 | #1 (permalink) |
Major Poster Join Date: Nov 2005 Location: TM Romania Age: 39
Member: 200647 Status: Offline Thanks Meter: 0 | J220 not connecting in USB-Smart br, calin |
09-02-2006, 10:26 | #2 (permalink) | |
Freak Poster Join Date: Sep 2005
Member: 178726 Status: Offline Thanks Meter: 69 | Quote:
With USB-Smart it's very hard to get the phone in test-mode. If you use UFS use UFS ATRz to unlock it. Direct unlock not possible, manual unlock. (Not accepted simcard, press '*', 'left', 'left', '*') If not using UFS, best with fully charged battery. Keep trying with power button. It's hard but, if you lucky you will get him in test-mode. So USB-Smart can read codes. Good luck with it. Kelvin | |
09-02-2006, 10:40 | #3 (permalink) |
Member: 200647 Status: Offline Thanks Meter: 0 | I have UFS but i can't use J220 (it is grey) in the phone list. And i don't have cable for it from UFS. Can i use the cable from USB Smart (Fitgher). And what should i try? Init Simlock? thanks very much calin |
09-02-2006, 10:54 | #4 (permalink) | |
Or you have to instal HWK Killer, use search option to find the installer. Succes! Kelvin | |
09-02-2006, 11:12 | #5 (permalink) |
Member: 200647 Status: Offline Thanks Meter: 0 | I have maneged to install hwk killer but i don't see any info button in UFS ATRz. What option shoul i try? I have buyed it a couple of days ago and i haven't managed to lear every thing. thanks a lot br, calin |
09-02-2006, 11:17 | #6 (permalink) | |
Kelvin | |
09-02-2006, 11:30 | #7 (permalink) |
Member: 200647 Status: Offline Thanks Meter: 0 | No it's not working . I think the cable it's not good. It is a rj45 but i don't know if it has the same pinout as the hwk cable. I will search for the pinout and try to modify it, Thanks alot calin |
09-06-2006, 16:47 | #8 (permalink) |
Freak Poster Join Date: Mar 2004
Member: 57254 Status: Offline Thanks Meter: 7 | I have 2 pieces at same time. One unlocked without problems with USB SMART. Second one can NOT connect to the USB SMART nor CRUISER. I used twister and fighter cable as interface. Can't explain !!! |
W810 Cann't Make Connection With USB-Smart | Afzaal | Sony Ericsson | 10 | 05-25-2007 07:24 |
K608i Cant Connect to USB-Smart or...... | thcoms | Sony Ericsson | 11 | 10-10-2006 20:35 |
C975 Not Connected In Smart Clip | zonetrichur | Smart-Clip | 5 | 09-24-2006 16:35 |
interface, 4-in-1 option missing in usb smart s.e | sallu | SonyEricsson (USB-Smart) | 3 | 07-02-2006 00:36 |
D750i not listed in usb smart! | loneunlocker | SonyEricsson (USB-Smart) | 5 | 05-17-2006 15:42 |
