Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 12-22-2005, 20:46   #31 (permalink)
Crazy Poster
Member: 45791
New Cruiser beta 7.12 should support cid49 repair... try it...
Old 12-22-2005, 20:58   #32 (permalink)
Cheater -Don't Deal with him-
khawar's Avatar
Member: 51218
Thanks Meter: 77
Cruiser 7.12.Now dn loading,and post result.
Thanks, for the tip.
WBR...KHAWAR
Old 12-23-2005, 02:52   #33 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 621
ı tested 7.12 same result may be cruiser kill hardware (RAM IC) ...... U take error message from cruiser FATAL ERROR EXTERNAL RAM NOT FOUND ?
Old 12-23-2005, 11:07   #34 (permalink)
Crazy Poster
Member: 45791
Yes I take that error...
But the phone was killed with Smart, I try to recover with Cruiser but no success.
Do you think this is an HW fault?!
Old 12-23-2005, 13:01   #35 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 621
ı dont sure but ı think hardware ...ked ı take always same error message cruiser EXTERNAL RAM NOT FOUND.. may be new updates solve...
and usb smart :
Switch phone ON
Get phone info
Flash CID (TP): 29
Phone KEY (TP): TEST_POINT
OTP CID (TP): 29
Send FS application
ERROR: 303002
Old 12-23-2005, 13:01   #36 (permalink)
Member: 10516
Yes same problem, no repair option for k608i cid49
regards
Andrews
Old 12-23-2005, 14:29   #37 (permalink)
Member: 76522
Thanks Meter: 30
at first i must say that lot of bugs r repaired! second flashing speed improved! thats great and big thx 4 u. but i have small sugestion can u make some script 4 automatic unlock rsa+replace brown secrt.+direct unlock?
Old 12-23-2005, 15:18   #38 (permalink)
khawar's Avatar
Member: 51218
Thanks Meter: 77
and usb smart :
Switch phone ON
Get phone info
Flash CID (TP): 29
OTP CID (TP): 29
Send FS application
ERROR: 303002
All CID 49 giving same error,and i think are gone forever. Both Zulea and Cruiser team, realeased incomplete solutions.Now there are hundreds of sets are dead.
I can not say ,who is responsible for all this,Zulea & Lead, Or we who trusted them.
Both of them are requested to help us.
WR.. KHAWAR
Old 12-23-2005, 15:46   #39 (permalink)
Member: 192180
Wow Dead Cid 49.
Thanks To Semc For Very Good Protection.
ROUND TWO FOR ALL 3RD PARTY GADGETS
Old 12-23-2005, 19:31   #40 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,448
WR.. KHAWAR
Make GOOD TESTPOINT (in phone) and try to NOT DESTROY ANYTHING (specialy resistor from testpoint) and all will be OK. I have tested and working well. If you (or somebody else) grounded another point from PCB there is chances to destroy Flash/RAM IC or CPU pins. Any software (USB-Smart, Cruiser, ...) CAN NOT DESTROY HARDWARE!! Hardware is destroyed ONLY by man who make/solder testpoint.
ERROR: 303002 = WRONG MADE TESTPOINT !!!
Best regards,
Zulea
Old 12-23-2005, 19:33   #41 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,448
Read my previous post. And specialy check the resistor from testpoint, it can be damaged or desoldered (by you or by another person).
Old 12-23-2005, 21:38   #42 (permalink)
khawar's Avatar
Member: 51218
Thanks Meter: 77
Best regards,
Zulea
Dear Sir ,I have done the test point 100% correctly and with great care and i assure you that there is nothing wrong with testpoint. I also do hardware repairing and daily do many Siemens & New Motorolas,with testpoints.
Now the position is,when i conect the phone with usb smart and try to flash ,it says that CID certificate not found ,but when i check the recover certificate option,the sw says that the phone already have certificate.
Please do something, the Lead has admitted the problem in cruiser and has promised to solve it.
ERROR 303002 is the problem of many people, Whereas no body has been successfull in reviving this phone.
WR... KHAWAR
Old 12-23-2005, 22:16   #43 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,448
WR... KHAWAR
If use Testpoint (checked option in software) software can NOT say Certificate not found or Phone already have certificete!! Post a screenshoot here!
Also regarding your post in "other forum" (check attached screenshoot), you must know that K600=K608 (regarding hardware inside). Of course there is 2 versions of PCB in this phones, but both can be find in K600 or K608 too!!
So, again, make correct testpoint on phone (you can find good testpoints here: http://forum.gsmhosting.com/vbb/show...27#post1460627 ), select right options in software (I explained more times here on forum how to repair k600/k608 - so use search button) and if your phone have not any hardware damage (made by others or by you) it works well 100%.
Best regards,
Zulea
Old 12-24-2005, 01:05   #44 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 621
Yes but Mr. Zulea phone zero (first ı open) and TP working resistor damaged possible?
Old 12-24-2005, 02:11   #45 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,448
Read here carefuly:
and try to use testpoint from V3 photo, who is equivalent with V1.
V1 and V3 testpoints from this link is find on same K600/K608 board type.
Best regards,
Zulea
what happens to www.mobile-files.com RotKT GSM Mobile Links 10 03-29-2010 12:25
What happen to mobile files dot com thushdt SETool2 1 03-21-2009 09:24
what happen to D900i after arabic flash file !!! tsarkh Samsung Flashers, Software, Firmware. 9 09-04-2007 00:27
what happened to all the flash files Vinod Rana UST Pro II 0 12-06-2006 17:34
What happened with 3220 flash files on support serwer? RafalTK Twisterflasher 0 02-03-2005 11:50
Page generated in 0.21834 seconds with 9 queries
