what't happen about w810 unlock ? now my w810 can't power on !! when i unlock w810i , show error below : Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35906xxxxxxxxx Flash ID: 2019 Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Send FLASH application Write GDFS Flashloader Switch phone ON Start GDFS Flashloader ERROR: 305328 |
try with new version of usb-smart. |
it's new version already !!!!!! |
Is the edition of v7.8? |
help plz can't detecte w810i on usb smart |
problem with w810 make sure battery is fully charged and you use latest version today is v85 then select correct com if using cruiser select cruiser cable and check what com is being used by it then connect phone and 9 volt battery which should be fully charged or new to cable then plug to phone and without battery click on do jos what ever it is you wanna do then insert battery if still not see phone clean or replace charging block as some get contaminated and need changing.i did 2 today . |
works fine mate, done lots of these already! |
Regards BladeGsm |
BR |
