zulea: k608 R2AG001_CXC1250079_CHINA_MI unlock when? when will this be suported? i have now a dead phone and waiting for the flash recovery feature for this phone? will it be soon? if not can i flash it with other version of k600i main and fs witout using testpoint? thanks |
Flash the phone with R2T files MAIN + FS + Complete (files is on support) and all will be OK. |
thanks a lot. will try. |
Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2000_49_RED OTP CID: 49 Phone IMEI: 35684200205417 Flash ID: 200D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Send FLASH application Checking MAIN flash file Send MAIN flash file: "K600_R2T002_ZONE1_STANDARD.mbc" MAIN flash sent OK Switch phone ON Send FLASH application Checking FS flash file Send FS flash file: "K600_R2T002_APAC1.fbc" FS flash sent OK Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2000_49_RED OTP CID: 49 Phone IMEI: 35684200205417 Flash ID: 200D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Reading flash CXC version Version: R2T002_CXC1250014_EU_1_MI Send FLASH application Recover first flash part Send FS application Start FS services Complete phone Please remove and insert battery before try to power phone! Operation succesfull still dead after this |
try to flash eprom files and then rebuild sp and crc...complete phone..unlock....If don't work...testpoint and full repair flash...... |
all is ok now.... vey good zulea, many thnaks |
use semc 7.5 Flash the phone with R2T files MAIN + FS + Complete (files is on support) without testpoint using a power supply as voltage source. and all is ok. |
