03-04-2006, 13:50 | #1 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 191662 Status: Offline Thanks Meter: 2 | Need help with 8380 patch unlock Do i need to download patch or is is built in LG software.....what do i do exactly to unlock LG 8380 via patch?????? |
03-04-2006, 14:31 | #3 (permalink) | |
Member: 191662 Status: Offline Thanks Meter: 2 | Quote:
03-04-2006, 14:35 | #4 (permalink) |
No Life Poster Join Date: Sep 2005 Location: UK, London Age: 35
Member: 177235 Status: Offline Sonork: 111568 Thanks Meter: 138 | you do not need patch files to unlock, its direct it will unlock the fone directly by reading the patch and doing everything it self thanks to zulea |
03-04-2006, 14:37 | #5 (permalink) | |
I KNOW ITS A SILLY QUESTION......QUICK RESPONSE WOULD BE NICE | |
03-04-2006, 14:41 | #6 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 44
Member: 100089 Status: Offline Thanks Meter: 1 | If you have problem, flash for example with this files: U8380_V10B_Italy_DRIVEC.zip 5.353 MB 10/08/05 15:04:11 U8380_V10B_Italy_DRIVEMEDIA.zip 2.293 MB 10/08/05 15:04:17 U8380_V10B_Italy_DRIVEREC.zip 8.867 KB 10/08/05 15:04:22 U8380_V10B_Italy_FLEXREC.zip 6.089 MB 10/08/05 15:04:29 U8380_V10B_Italy_PHONE.zip 7.612 MB 10/08/05 15:04:36 And after use Lg3gtool v2.7 with the option "unlock all network lock" (this is the only operations do you make for direct lock if your phone is ok with the formware) Also, for use the testpoint, please select your model and TP to flash or unlock Bye. |
03-04-2006, 14:42 | #7 (permalink) | |
Member: 100089 Status: Offline Thanks Meter: 1 | Quote:
The patched files is ready from many times with setool and furious, etc.. Now, with this and other tool (lick usb smart, vygis etc... you can use direct unlock) | |
03-04-2006, 14:49 | #8 (permalink) | |
03-04-2006, 22:21 | #10 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: not fixed yet
Member: 138305 Status: Offline Thanks Meter: 2 | Quote:
else flash original firmware ( as Your choice ) from Support, then unlock | |
03-23-2006, 07:59 | #11 (permalink) | |
Freak Poster Join Date: Oct 2002 Location: Kenya
Member: 16275 Status: Offline Thanks Meter: 10 | Quote:
there is five files to flash only for option for four files in software where do you load the extra flash phone will go to phone driveC will go to DriveC drivemedia is also straight forward where do you load files FLEXREC & DRIVEREC cos only fs is empty? | |
03-23-2006, 09:05 | #12 (permalink) | |
04-01-2006, 12:35 | #13 (permalink) |
Freak Poster Join Date: Mar 2002 Location: SWEDEN, Malmoe Age: 45
Member: 10228 Status: Offline Thanks Meter: 2 | Switch phone ON ... Get phone info OTP CID: 41 Phone IMEI: 355xxxxx378090 Flash ID: 890D Send FLASH application ... Read blocks ... Patch CHECKSUM block ... Patch SIM2G block ... Patch SPLOCK_PHONE block ... Patch SPLOCK_DRIVEC block ... Write blocks ... Patch Unlock OK Phone unlocked ok, but big screen goes black after 2-3 seconds then you have to remove battery to restart. What to do? Its a 8380. /Returburk |
04-01-2006, 19:20 | #14 (permalink) | |
need help with ****** 3.1 unlocker | jab | Sharp | 0 | 02-27-2004 21:00 |
Need help with this patching problem | atifprince | Siemens-Benq Flash Patching | 3 | 10-17-2003 22:00 |
need help with 7650 direct unlocker | geosan1638 | WD2 & APE (Symbian Phones) | 2 | 01-24-2003 14:20 |
Need Help With Dancal 2611 Unlock | IceKiller ZLIN | Various | 0 | 07-17-2002 19:07 |
Need help with V60/66 unlock cable sxematic diagram | andrews | Motorola P2k | 0 | 05-31-2002 05:13 |
