07-31-2006, 01:44 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 246621 Status: Offline Thanks Meter: 2 | Dead V3 only keyboard lite up I have a dead V3 RAZR with only Keyboard lite up. What are the procedures to repair this phone. I know you have to repair the PDS but does that require testpoint? Thanks! |
08-01-2006, 20:13 | #3 (permalink) |
No Life Poster Join Date: Feb 2004 Location: ROMANIA Age: 46
Member: 55427 Status: Offline Thanks Meter: 7 | craxx99, what means "only Keyboard lite up"? this happens when you connect battery or when you power on the phone? And second: you need to make TP for any flashing/repair opperation BR, xyz |
08-03-2006, 05:57 | #5 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Colombia Age: 46
Member: 111340 Status: Offline Thanks Meter: 8 | V3 Dead First check flash, if your phone is detected in flash mode for RSD lite , you can flash (fullflas) and try power on If your phone no power on try write bootloader, maybe 07E0 and try to flash again Good Lucky |
08-03-2006, 07:30 | #6 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 45
Member: 139388 Status: Offline Thanks Meter: 98 | For flashing motorola V3 for display problem in Smart clip an seniour poster gaved the what are the flash files to use in smart clip R374_G_0E.42.07R_A R374_G_0E.42.08R_A R374_G_0E.42.0CR Those files could be used as a solution for the handsets with nonworking internal display after flashing with 9CR version of flash file.) But i dont have smart clip I am having only usb smart But i dont know which files to select to flash Can anyone know which files to select in usb smart for flashing V3 for display problem Needed good advice |
08-07-2006, 20:36 | #9 (permalink) | |
No Life Poster Join Date: Dec 2003
Member: 46387 Status: Offline Thanks Meter: 139 | Quote:
Press *,# and power in the same time | |
08-13-2006, 20:56 | #10 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Italiaf Age: 65
Member: 135097 Status: Offline Thanks Meter: 22 | Yes my friends this is right way.But i got one piece that go*+# power on for few seconds blink key-board and power off.USB no detect it.Who can help? best regards |
RAZR V3 dead screen - Only keypad lights up | lmckdhu | Smart-Clip | 5 | 05-12-2009 09:36 |
D600 only keyboard litghts up. | barrieb | SWIFT Platform | 2 | 01-10-2008 18:55 |
HELP V3 only keyboard lights up | ticktock | Smart-Clip | 4 | 01-14-2006 17:58 |
Motorola v3 only light keyboard | Carlazos | Motorola P2k | 12 | 01-12-2006 14:37 |
MOTOROLA V3 dead, only keyboard lights !!?? | jode | Motorola P2k | 25 | 12-01-2005 19:27 |
