05-27-2006, 14:18 | #1 (permalink) |
Junior Member Join Date: Apr 2006
Member: 259620 Status: Offline Thanks Meter: 0 | Flashing Language pack Processed 9 codegroups Connecting to phone ... Switching to P2K mode ... Connected to: 'Motorola Test Interface' Switching to flash mode ... Connected to: 'Motorola Flash' Connected OK Sending RAM loader ... ERROR: FLASHCMD read error Error during post-JUMP commands. Error while flashing RAM loader, aborting. ERROR: Flashing failed hi.. just then i try to use RSD lite and flash the chinese firmware.. but it keep failing and say some "jumping error"... what does that mean.. i then went to the solution of using the special language packs using p2k easy tool... it flashed ok with the 0024.lng .... but when i turn on the phone and go to language settings the chinese became block letters like "[][][][][]"... is there anyway i can put chinese in without any trouble? edit: do i need to tp to flash v3x? right now i flashed it with a chinese flash lp... but it seems tat the phone Os dun support the language... ("[][][]" instead of chinese) or do i need a new flex to support the language? Last edited by macky112; 05-27-2006 at 16:15. |
05-28-2006, 04:54 | #2 (permalink) |
Member: 259620 Status: Offline Thanks Meter: 0 | anyone? i really need advice on this... i can only flash language files (lng.) and not the (.shx)... although the chinese did flash properly into the v3x it shows up in blocks... and i don't know what else to do. Processing input file: Processed 9 codegroups Connecting to phone ... Switching to P2K mode ... Connected to: 'Motorola Test Interface' Switching to flash mode ... Connected to: 'Motorola Flash' Connected OK Sending RAM loader ... ERROR: FLASHCMD read error Error during post-JUMP commands. Error while flashing RAM loader, aborting. ERROR: Flashing failed |
05-28-2006, 17:27 | #3 (permalink) |
Product Supporter Join Date: Mar 2005 Location: Poland
Member: 123230 Status: Offline Sonork: 100.113333 Thanks Meter: 14 | support >> p2k_original_flash_flex >> V3x : R252211LD_U_85.97.80R_lang0016_flash.rar - langpack (with chinese) R252211LD-AS_U_85.92.B0R_LP0024_DRM0001_VSTU_206_050C_JPSI_R 25221GENERIC_03_USRAZRV3XT676CYR2522100D.rar - ******* pack (also with chinese) Flash it with RSD Lite ! Regards |
05-28-2006, 23:45 | #4 (permalink) |
Member: 259620 Status: Offline Thanks Meter: 0 | flashing the language pack gives me the same problem (gives me block letters then chinese) and the *******pack doesn't work.. gives me the same error commands i stated above... including the (critical error 10 39 on the v3x lcd) i think my boot loader or version is too new.. i need to find a chinese ******* pack newer then 0.6.8.2 or something -_- sigh... thanks for ur help though |
flash language pack french for pana G60 | kimo59 | Panasonic | 3 | 07-20-2006 13:23 |
Help Flashing Language Pack V3 | sgpstar | Motorola P2k | 2 | 03-22-2006 09:31 |
enough to flash main .rel file or need to flash language pack as well | miq | Panasonic | 1 | 10-01-2004 12:46 |
fisio 120 how to flash language packs? | surfer2go | Philips | 4 | 11-04-2003 07:47 |
I need For Zulea Roemmi Flash Language Pack | YaSSaX | Motorola Old Legacy (EMMI) | 0 | 10-15-2001 12:32 |
