Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Dongle Problems (USB-Smart)
Dongle Problems (USB-Smart) Dongle probelms and installation support
Old 06-28-2006, 22:01   #1 (permalink)
ottyone's Avatar
Member: 35205
Thanks Meter: 14
No found Twister/HWK 4 access
hallo,
what that ?
Boot: UFxBoot V2.2 (c) SarasSoft 2003.
Build: UFS_USB V2.6 (c) SarasSoft 2005.
Activation string response: 2A
whats wrong ?
please help.....
BR.
Old 06-30-2006, 07:25   #2 (permalink)
MANOLE
Guest
Posts: n/a
Member:
Ask saras soft for this
BR,
Manole
Old 06-30-2006, 11:44   #3 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@ottyone
PROBLEM IS YOU ARE USING NEW UFS DRIVER.....
GO TO THIS LINK
http://www.evil-hackers.com/stanner_.../UFS%20REPAIR/
DOWNLOAD "ufs_drivers_last_v10606.zip"
UPDATE YOUR DRIVER WITH IT.......
AND INTERFACE WORK 100%
Old 06-30-2006, 19:01   #4 (permalink)
ottyone's Avatar
Member: 35205
Thanks Meter: 14
No - donīt work - same problem as before
Old 07-01-2006, 08:42   #5 (permalink)
Member: 49752
Thanks Meter: 6,085
you are able to connect with any sara soft software like
dctx or samsung or any one??
if yes then check driver name in device manager.....or post that device manager pic hear.........
Old 07-01-2006, 10:31   #6 (permalink)
ottyone's Avatar
Member: 35205
Thanks Meter: 14
yes - with UFS_DCTxBB5 i can connect the box, but after change driver, i have put in the aktivation-string again.
here the pic from the device-manager
Old 07-01-2006, 10:49   #7 (permalink)
Member: 49752
Thanks Meter: 6,085
Ok Now Post Pic That You Get Error
On Frist Post You Writed
Old 07-01-2006, 11:36   #8 (permalink)
ottyone's Avatar
Member: 35205
Thanks Meter: 14
ok - here it is
Old 07-01-2006, 11:38   #9 (permalink)
Member: 49752
Thanks Meter: 6,085
Unplug Ufs
Plug Again
Reupdate Driver That I Posted And Agan Start This Version And Tell Results
ps:when you updating driver its show you overwrite existing one click on YES then you will able to use ...
Old 07-01-2006, 12:13   #10 (permalink)
ottyone's Avatar
Member: 35205
Thanks Meter: 14
No - don´t work - same problem as before
Old 07-01-2006, 12:34   #11 (permalink)
Member: 49752
Thanks Meter: 6,085
TRYED THIS ONE ALSO?
IF YES THEN SORRY NOW I CAN'T HELP YOU....I THINK WINDOWS PROBLEM CHECK ON ANOHTER FRESH PC...
Old 07-01-2006, 13:35   #12 (permalink)
ottyone's Avatar
Member: 35205
Thanks Meter: 14
the problem was start when i update the hwk by use the Twister-hwk-setup 3.0 -- then the trouble starts
now i´ll remove all drivers and software from twister,hwk and smart-dongel.
cleanup the registry and reinstall the newest setup-software.
Old 07-01-2006, 18:09   #13 (permalink)
Member: 161279
Thanks Meter: 3
Smile
@ottyone
GO TO THIS LINK
Bravo.....i think u right..... thank alot.....
Old 07-10-2006, 11:35   #14 (permalink)
Member: 203606
sir my twister box not support hwk clone plz whz can i do
Old 08-20-2006, 09:13   #15 (permalink)
Member: 72249
Thanks Meter: 2
hello please help ,i have problem with usb smart ,when i chose twister/ufs on interface ,it says can not connect twister/ufs. regard williams
unlocking k300i with twister hwk kharr HWK 13 04-06-2007 20:06
no Twister/HWK 4 accsess ottyone HWK 2 07-18-2006 18:21
twister hwk kharr Twisterflasher 5 10-02-2005 16:24
e720 And Twister/HWK Termy HWK 6 09-01-2005 01:41
Jaf Special $120! Nsdongle, Cruiser, Twister, Hwk, USB SMART, Smartclip All Instock! UnlockCellular Main Sales Section 0 08-01-2005 16:40
Page generated in 0.26812 seconds with 10 queries
