Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Dongle Problems (USB-Smart)
Dongle Problems (USB-Smart) Dongle probelms and installation support
Old 06-12-2006, 23:34   #1 (permalink)
Member: 105625
Thanks Meter: 44
Not possible to have more than one Bluez Smartcard?
When i insert Twister support dongle, while USB-smart is connected i get the "usb failed" sound. If i remove usb-smart and connect it, it connects fine.
Isn't it possible to have more than one of these cards connected at the same time?
Old 06-13-2006, 00:12   #2 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 100
You have to go into your device manager, select e-gate enumerators, and increase number to 2 or 3, at your choice. After doing that, I can use reseller dongle and twister dongle or usb-smart at same time.
br
Old 06-13-2006, 00:56   #3 (permalink)
Member: 105625
Thanks Meter: 44
Hmm. It's driver problem:
This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
Click Troubleshoot to start the troubleshooter for this device.
Old 06-18-2006, 07:38   #4 (permalink)
Member: 150697
Thanks Meter: 7
should be ok if you install both cards on separate USB port at different times.
do each card individually while the other card is sitting on desk!
Is it possible to use more than name on one box? nabhan9 Universalbox 0 03-28-2009 00:08
i have a big problem with moto l6 i flashed it more than one time and it also blank dvdaio MSS Box II 9 06-25-2008 19:49
How to select more than one file in setool? MrDevil SETool2 3 06-16-2008 12:44
IMSI is OK , but not possible to have KI hfathollahi Sim Cloning and Scaning 8 09-06-2004 07:31
How to get more than one..... cole Griffin 2 03-19-2004 12:15
Page generated in 0.13740 seconds with 9 queries
