Cingular USA 8125 flash Just received a Cingular USA 8125 to flash to another language. Is it okay to use any of Wizard flashes at support? How can I unlock it? Best Regards, UnlockBR |
Are my questions too obvious? Regards, UnlockBR |
the only flash for cing 8125 in support doesnt even work with jafwm and you need to purchase credit for about 30$ usd for unlock. sorry for bad news. Quote:
(Question has some months now ;) ) |
where do you get files? i need spanish for one of these tks for answer |
hi for future you can flash any wizzard file that is higher or the same as the ipl/spl even if its g4. i flashed a Qtek phone version 2.17.001 that is g4 with cingular 2.25 rom and it worked 100%. you can even hack the registery to keep the azerty keyboard. just dont uncheck the skip ipl/spl now, if your going from 1.0x to 2.25 you have to flash ipl/spl or you wont get service. |
i killed one 8125 yesterday.it have last version but some problemsin touch pad. now is in flash mode only. i read something in others forum and the solution is wait for new upgrade different to my original fw and then will be ok. very complicated to learn that stuffs. |
your 8125 might have had 2.25.0001 in this case you can only flash same or newer firmware.. maybe you try to flash lower firmware. try to flash again.. dont uncheck the skip ipl/spl if its g4, cause the firmware available is for g3. |
yes i try t flash whit same version in phone and in support .where i can get older version? |
Be carefull also that the battery should be fully charged before flashing. Other wise phone will get stuck in flashmode. This happened to me and after I fully charged it I was able to flash it completely. regards, JOHNNY. |
(Already solved. Thanks anyway. ) can u plz tell me how do u solve it?????? |
at xda-developers just browse its forum ;) |
i downloaded the flashfile of 8125 its end with .NBA how do i flash it,with this file.i flashed it with a g3 flashfile and the language changed,i will like to flash it with the cing 8125 flasfile so as to change it to english..how do i flash it the flash ends in .NBA |
My cingular works fine before. I try a factory settings and reset phone starts now in boot loader mode. I dont know wich file choose in xda forum cause support roms is out of date cause its ipl/spl 2.25.0001 |
Need help about sing 8125 lock after factory seting.Anybody know how can I silve this problem.Its very argent. |
