Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SE Power Clip & Turbo Unlocker
SE Power Clip & Turbo Unlocker SE power Clip & LG Turbo unlocker
Old 03-13-2006, 06:53   #1 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
se power clip not work or?
I updated se power clip to latest version ok, but up to now never got one se to unlock with this clip, anyone has success with it? and how? so far waste of money, but maybe someone here can help, thank you.
Old 03-14-2006, 02:22   #2 (permalink)
irishclips's Avatar
Member: 84155
Thanks Meter: 8
What is so good about this clip??
Piranha clip had CID 49 a long time ago (same models) and it also does all XDA, MDA etc etc and Samsung and LG and MPX???
And no, I am not rying to be funny, I am curious as to why I should sell this clip and not Piranha?
Old 03-15-2006, 17:39   #3 (permalink)
Member: 87413
Thanks Meter: 3
Smile SE Power Clip
50% Cheaper is Price then the Piranha Clip.
Reseller Make more and end user save more.
Easy to use and free update.
Old 03-16-2006, 11:15   #4 (permalink)
Member: 243073
You should contact your reseller. W600i was a problem but with latest update v1.6 W600i unlocking is no longer an issue.
Old 03-17-2006, 14:04   #5 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
It update 100% ok version 1.6 but never unlocked any SE, tried many different models, from T300 , T226, T237, T610, to W600, Z500, Z520 never unlocked one.
procedure: no sim power on and turn off, connect to clip, power on clip, red light blink fast, then blink slow then both lights blink even slower wait 2 minutes disconnect and test but still locked. like stated before waste of time and money.
Old 03-26-2006, 17:53   #6 (permalink)
Member: 143588
Lightbulb This is how you use the SE Powerclip
When I first got this clip, I thought it was a paper weight piece of junk. The website offers the free updates, but nothing more on the operation of the clip. That is what is causing all the problems. The clip does not operate as easy as they claim. So far I have unlocked a Z520a,T616,T237 etc. The sellers of this clip say you have to downgrade or upgrade the software on the clip depending on the phone you are trying to unlock. So where is the list on what version is compatible with what phone????? If you want to know how to operate it instead of just staring at it expecting some sort of miracle, email me.
Old 03-27-2006, 18:25   #7 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
please post here for all, thanks.
The Following User Says Thank You to mrfixit For This Useful Post:
Old 03-29-2006, 07:18   #8 (permalink)
Member: 243073
To Unlock Z520a or W600i models you will need to upgrade your clip to v1.8. (Check my other post)
To unlock older phones T68, T610, T616, T637 etc. you can downgrade the Clip to Version 1.1
If you are still having problems with your Clip, contact your reseller or contact me at [email protected]
Old 04-08-2006, 04:48   #9 (permalink)
Member: 238059
To unlock cingular Z520a and W600a...you need two power sources...one is connect to the cable (Must use 9V Battery)...one is connect to the clip. If you only use 1 power source...it will not unlock the phone. Other older types, you don't need to use two power sources. If your new type SE unlock clip cable do not have a 9V battery connector...I'm afraid it will be useless!!!
Old 07-23-2006, 05:28   #10 (permalink)
Member: 312383
Thanks Meter: 6
Blazer help, cant unlock lg cg3000
Old 07-31-2006, 01:21   #11 (permalink)
Member: 226179
Thanks Meter: 12
your device is useless i got the piranha long time i can unlock anything it is only for unlooking not for unlocking...........hahahahahaha
Old 07-31-2006, 01:24   #12 (permalink)
Member: 226179
Thanks Meter: 12
i need my usermane and password to be activated im telling you how many times ......what happen......
thanks,
How unlock Z630 with only CLIP I need instruction becosue only power on not work !! wgmmmx Ultimate-Sam 3 08-06-2009 09:42
SE T100 power key not working de brain box Sony Ericsson Hardware Repair 0 09-23-2006 05:26
Se Power Clip Cid 49 Mr Twitch MT-BOX 2 03-14-2006 20:12
SE-POWER CLIP - First stand alone unlocker CID 49 A-1Wireless SE Power Clip & Turbo Unlocker 0 03-10-2006 17:30
Page generated in 0.26374 seconds with 9 queries
