SE Power Clip & Turbo Unlocker SE power Clip & LG Turbo unlocker |
05-16-2006, 03:05 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 209516 Status: Offline Thanks Meter: 0 | Se Power Clip Cannot Unlock T237 I'm trying to unlock a T237. The clip starts by clicking but one led turns off and the other one blinks. Then it stops for a second and it goes at it again. It goes for about 6 cycles then both leds flash. How do i unlock this? |
05-22-2006, 05:18 | #2 (permalink) |
Junior Member Join Date: Mar 2006 Location: Washington, USA
Member: 243073 Status: Offline Thanks Meter: 0 | Check the firmware version of your clip. If version 1.10 (latest) you will need to downgrade your clip to version 1.01 to unlock older phones. Takes 5 minutes to do this. |
05-26-2006, 02:56 | #4 (permalink) |
Member: 243073 Status: Offline Thanks Meter: 0 | It takes just 5 minutes to upgrade/downgrade? I am sure the dev is working on this I agree it should be fixed but I think the W600i is eating up too much memory and for the time being it is not too bad. USAunlocker Selling unlocking solution is just not business it is our passion! http://stores.ebay.com/USA-Unlocker_W0QQsspagenameZMEQ3aFQ3aSTQQtZkm |
06-01-2006, 22:49 | #6 (permalink) |
Junior Member Join Date: May 2005 Location: AZ Age: 52
Member: 143588 Status: Offline Thanks Meter: 0 | The latest version covers them ALLLL! Ok guys listen carefully. There is no need to downgrade. Almost every phone is different in the technique you should use. Some phones are as easy as turning on the clip and some phones require action on your part. 1. Take the cover off the battery 2. Phone in the off position: Turn on your clip 3. If the phone turns on, don’t worry about it 4. Press the power button on the phone to interrupt the clip from blinking. For some reason this interrupts the clips “thinking” and restarts the process on the clip. ( or so it seems ) 5. Press the power button on the phone every 5 seconds until the light glow a SOLID red and your phone is unlocked. If the button doesn’t interrupt it, take the battery and push it back in. You will get the hang of it eventually. Happy Unlocking!! |
06-26-2006, 15:18 | #7 (permalink) | |
Member: 209516 Status: Offline Thanks Meter: 0 | Quote:
07-29-2006, 18:29 | #9 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 41
Member: 110714 Status: Offline Thanks Meter: 0 | wassup guys. If you are looking to unlock or flash sony ericsson, i highly recommend you to get a Cruiser. It is only $109 plus shipping. Cruiser support older and new models such as w810i. It is very easy to use. |
11-14-2006, 21:26 | #10 (permalink) |
Junior Member Join Date: Apr 2006
Member: 258979 Status: Offline Thanks Meter: 0 | How do I downgrade the powerclip? I don't know where to get the files. I tried everything 'xelarey' suggested and I when the clip finishes going through the programming mode, the leds just flash and the phone is still locked. I looked on the 'sepowerclip.com' site but the only thing I find is the latest version software. Thanks in advance for all help that is offered. Last edited by TymezUp; 11-15-2006 at 01:38. |
11-17-2006, 22:42 | #11 (permalink) |
Member: 243073 Status: Offline Thanks Meter: 0 | talk to your reseller. If that does not work email me at [email protected] |
se power clip not work or? | mrfixit | SE Power Clip & Turbo Unlocker | 11 | 07-31-2006 01:24 |
How do I check the firmware version of my SE Power Clip? | USAUnlocker | SE Power Clip & Turbo Unlocker | 0 | 04-11-2006 11:48 |
Se Power Clip Cid 49 | Mr Twitch | MT-BOX | 2 | 03-14-2006 20:12 |
SE-POWER CLIP - First stand alone unlocker CID 49 | A-1Wireless | SE Power Clip & Turbo Unlocker | 0 | 03-10-2006 17:30 |
