Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
01-06-2007, 20:47 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | InfraRed rework station inquiry i have just bought T862 IRDA rework station & i have realized that it doesn't work with real infrared beams & it's only a high output AC lamp that generates a high temperature & with that it can desolder & solder, i'm not saying that it's fake & doesn't work it's just little slow & i have to adjust it to the max temperature 350 to be able to desolder & solder & less than that it will take very long time. and now i want to know is there other rework stations that works with real infrared beams or all of them works the same way as this one, many thnx for all & best regards ... |
The Following User Says Thank You to mobilagy For This Useful Post: |
01-06-2007, 21:23 | #2 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | ....all are same byt you must to have a preheater to use this kind of stations, it is used to heat PCB......basicly preheater is caramic grill which heats your PCB from 100-400C , for me works good at 200C for all leadfree phones, qand yes it takes more time to heat all PCB, then work on it, them need some time to wait for cooling PCB then - tests etc WBR |
01-08-2007, 14:48 | #4 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 49
Member: 6524 Status: Offline Thanks Meter: 246 | working well Hi mate, u need bottom pre heater for irda rework..in irda rework 12 v150w buld..that not genarate high temp..irda focus lense making high temp..so use bottom pre heater..look this attachment |
The Following User Says Thank You to GSMsurgeon For This Useful Post: |
01-15-2007, 01:05 | #5 (permalink) | |
Junior Member Join Date: Jan 2007
Member: 429470 Status: Offline Thanks Meter: 0 | Quote:
01-29-2007, 07:23 | #6 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | well dudes, i have realized a new info for me & i don't know if it's for much or less of you & it's that rework station T-862 works really with infra-red but it called "visible ir" & it depends on a halogen lamp & a gold coated reflector & it's indeed the gesign of the lamp that this rework station works with. i have get this information when i was browsing the internet looking for good lamps for this machine that i valuable it now more than before |
07-25-2007, 18:58 | #7 (permalink) |
Freak Poster Join Date: Jul 2002 Location: .UK Age: 45
Member: 13459 Status: Offline Thanks Meter: 6 | Hello all, A little bit old topic, thx for infos, I-ve just bought the T862 station from SquareGSM, it is a wonderful tool, I've used the infos above, with preheated pcb at 150, max 200 degrees celsius, it works perfect. I've changed SIM IC's in Nokia near SIM holder and no damage to plastic! SUPER TOOL! If anyone have more info, tips and tricks, please post here! Regards, AirBoy |
07-26-2007, 04:16 | #8 (permalink) |
Product Supporter Join Date: May 2001
Member: 4566 Status: Offline Sonork: 100.112355 Thanks Meter: 503 | Hello all, These rework stations uses chinese lamp (copy of pdr, the pioneer in IR lamp technology) but the lamp has fixed lens that force light to generate high temperature. Lamps can easily get busted. Our new Tornado Infra Station, the worlds first handheld infra rework station, uses ceramic IR, one of the best in the IR technology. Ceramic IR radiators are electrical heating elements consisting mainly out of a technical ceramic being high-temperature resistant and has long service life due to an embedded heating coils. The tornado infra has reasonable price without degradation of its quality, easy to use, without too much complications. Or you can pm me directly. regards, ren Last edited by Raheeeeb; 07-26-2007 at 18:26. Reason: edited due forum rules number 12 and 13 |
03-25-2009, 23:25 | #11 (permalink) |
Insane Poster Join Date: Apr 2004 Age: 44
Member: 63932 Status: Offline Thanks Meter: 2 | InfraRed rework station Thatt's some real good IR rework equipement,... but not cheap. ERSA: http://www.ersa.com/index.php?modul=...6&cont_add=467 ERSA: http://www.ersa.com/art-irhp-100-346-1482.html ERSA: http://www.ersa.com/art-smt-bga-rework-346-1474.html and IR rework station that use people from this forum> Jovy Systems RE 7500 Rework System (ERSA IR-500A, IR-550 analogue) http://www.jovy-systems.com/index.asp Regards, Alex?G |
03-25-2009, 23:40 | #12 (permalink) |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | irDA - T860 station using videos http://www.youtube.com/watch?v=S2DcX...eature=related |
The Following User Says Thank You to SHOEB AHMED For This Useful Post: |
03-26-2009, 00:30 | #13 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Infra Red is more fantastic than functionnal !!! It have you believe there is something specific because of using Infra Red Let's have a look at T862 for example, this is even not infra red, they wrote IRDA on it ! Good News, who knew that IRDA data connection is able to solder sth ??? Aren't they playing with people ?? Back in 1999 years, when first bga phones where out ( V3688, L7089, 8810, 8210, 3310, T18s, T28s, T20s , expensive INFRA RED stations were great to use on old phones ( JVC PDR, ZEVAC, ... ) Nowadays many phones are made with sensitive components like rtc batterys or Electrolytic Diodes that may blovv/explode with IR so they are easier to be reworked with HOT AIR bga stations , because Infra Red heat flow isn't as sharply controlable as hot air is. Infra Red requires a warm plate from under, and the infra red light gets the heat focused from the bottom to the top. Hot Air is more convenient to solder local parts successfuly, without heating the whole board. Now this is a Hot Air era Check hot air bga stations from : Martin, Weller, Bokar ... And don't be fooled no more, because of scientific words ... BR Max_B |
03-26-2009, 00:43 | #14 (permalink) |
Member: 63932 Status: Offline Thanks Meter: 2 | Quote: Originally Posted by tiju kkm View Post i need InfraRed rework station using videos irDA - T860 station using videos http://www.youtube.com/watch?v=S2DcX...eature=related I had chance to test thsi device, and i can't say that it's something WOW,... will make more test and that can say more. BR, A_G |
03-26-2009, 19:11 | #15 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: KERALA KUNNAMKULAM
Member: 699986 Status: Offline Sonork: TIJU Thanks Meter: 394 | Quote:
infrared rework station | dineshharsh | Sell ur Old and Used Stuff | 3 | 09-24-2009 09:07 |
i need Hot air rework station and soldering station! | zdob | Main Sales Section | 7 | 10-14-2001 09:48 |
I need Hot air rework station and soldering station! | zdob | Hardware Equipments for GSM | 7 | 10-10-2001 15:55 |
I need Good soldering station and Hot air rework station! | zdob | Hardware Repair by brands | 0 | 09-24-2001 12:02 |
