Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 10-29-2019, 21:19   #1 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
Make Short Killer Tool Free
in my carrier receive many dead short phones some was repaired after hard work of hours some returned without repair----
chinese make a tool short killer 60$ find out shortage and repair phones..
HERE WE ARE GOING TO MAKE IT FREE AND FREE
1-
CHECK THIS PHONE FULL SHORT
2-
CHANGE METER PROBE STILL FULL SHORT
3-
OPEN ANY POWER BANK AND REMOVE BATTERY
4-
CONNECT GROUND BLACK POINT TO GROUND AND RED ON BATTERY +
JUST FOR 3 SECONDS
5-
AND YOU WILL GETT BURN CAPACITOR LIKE THIS SOME CASEES IC PROBLEM THEN IC WILL HEATUP USE FLUX OR SPRAY TO FIND
MINE WAS CAPACITOR
6-
FINALY REMOVE BURN CAPACITOR AND PHONE IS WORK
<BEFORE I WAS WORK ON 2 J1 REMOVE ALMOST EVERYTHING CAP IC ON BOARD SPENT HOURS BUTT SHORTAGE WAS NOT REMOVED>
BUTT TODAY ITS TOOK 2 SECOND
AS I WRITE WE ARE GOING TO MAKE IT FREE EERY ONE SO POST YOUR IDEA AND PICTURES HERE TO IMPROOVE AND ADD MORE FETURES IN SHORT KILLER TOOL
MY IDEAS
1-CAN ADD FUSE 0F 5 TO 10 AMP FOR SAFETY
2- CAN ADD VOLTAGE REGULATOR
BATTERY MOSTLY GIVE 3 TO 5 VOLTS
BUTT WE CAN RGULATE AND START CHECKING FROM 2 VOLTS
IFF SHORTAGE NOT DETECT INCREAS VOLTAGE 3,4,5....
ITS IMPORTANT FOR BOARD SAFETY HIGY VOLTAGE MAY DAMAGE PRINTS OR CPU OR EMMC OR ANOTHER SO START WITH 2 VOLTS
SHARE YOUR IDEAS FOR IMPROOVE YOUR SELF MADE SHORT KILLER PICTURES
AND ALSO COMMENTS ABOUT THIS THANKS
The Following 29 Users Say Thank You to chand_gee For This Useful Post:
Old 10-30-2019, 04:48   #2 (permalink)
Member: 328688
Thanks Meter: 2,282
Very good work keep it up
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post:
Old 10-30-2019, 06:42   #3 (permalink)
Member: 1251098
Sonork: 100.1615825
Thanks Meter: 32
good idea sir thankx
The Following User Says Thank You to tariqpak74 For This Useful Post:
Old 11-01-2019, 22:40   #4 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
very useful thread , very good bro .thanks
The Following 2 Users Say Thank You to orx For This Useful Post:
Old 11-02-2019, 02:38   #5 (permalink)
Member: 2453575
Thanks Meter: 34
Tablet clone battery is tested to..
The Following User Says Thank You to nivram23 For This Useful Post:
Old 11-02-2019, 10:12   #6 (permalink)
..Ali Abbas..'s Avatar
Member: 2191194
Thanks Meter: 75
thank you brother..!
you are a true helper. keep it up.
MAY ALLAH BLESS YOU ALWAYS
The Following 2 Users Say Thank You to ..Ali Abbas.. For This Useful Post:
Old 11-08-2019, 09:19   #7 (permalink)
Member: 1138694
Thanks Meter: 72
here we are going to make it free and free
1-
check this phone full short
2-
change meter probe still full short
3-
open any power bank and remove battery
4-
connect ground black point to ground and red on battery +
just for 3 seconds
5-
and you will gett burn capacitor like this some casees ic problem then ic will heatup use flux or spray to find
mine was capacitor
6-
finaly remove burn capacitor and phone is work
<before i was work on 2 j1 remove almost everything cap ic on board spent hours butt shortage was not removed>
butt today its took 2 second
as i write we are going to make it free eery one so post your idea and pictures here to improove and add more fetures in short killer tool
my ideas
1-can add fuse 0f 5 to 10 amp for safety
2- can add voltage regulator
battery mostly give 3 to 5 volts
butt we can rgulate and start checking from 2 volts
iff shortage not detect increas voltage 3,4,5....
Its important for board safety higy voltage may damage prints or cpu or emmc or another so start with 2 volts
share your ideas for improove your self made short killer pictures
and also comments about this thanks
dear.
Pl.share 100k tone controle log or linear .
Jaideep mehta
india.
The Following User Says Thank You to mehta jaideep For This Useful Post:
Old 11-29-2019, 09:35   #8 (permalink)
Member: 671754
Thanks Meter: 11
u had a good idea about reopening short circuit and finding short but i think it will cause trouble if wil mislead how to use ur newly invented tool. beside that not all short u will find in that way make a new good voltage cicuit analyser to find voltage drop i d folowing circuit... but i really appreciate ur concerned
Old 11-30-2019, 09:26   #9 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
1-
2-
3-
4-
JUST FOR 3 SECONDS
5-
MINE WAS CAPACITOR
6-
MY IDEAS
Thank you so much chand gee for ur hard work i have been using the same trick since from two years its very helpful ...............sorry for i didnt mentioned it this b4.................
Old 12-06-2019, 02:22   #10 (permalink)
Member: 1354113
Thanks Meter: 669
How to make short killer
Any demo videos plz share
Old 12-11-2019, 15:51   #11 (permalink)
Member: 2923502
Thanks Meter: 6
Thanks for this frend it's great idea can repair lap tops with this,I see similar schematics with lm317 nd 2n30555
G R E A T
Old 12-11-2019, 16:08   #12 (permalink)
Member: 2923502
Thanks Meter: 6
The Following 2 Users Say Thank You to gsmphonerepair For This Useful Post:
Old 05-24-2020, 16:51   #13 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 115
Why use battery and not power supply?
Old 07-17-2020, 10:30   #14 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
1-
2-
3-
4-
JUST FOR 3 SECONDS
5-
MINE WAS CAPACITOR
6-
MY IDEAS
hi
with diy shortkiller , my doubt is ..voltage regulator like LM317 or i can to use a transistor as you wrote ? already done with lm317 but it has a SPC (short protection) when give injection with 2v power goes stop .. thanks
image from my idea
Old 07-22-2020, 03:58   #15 (permalink)
kham's Avatar
Member: 3026
Sonork: 100.1602750
Thanks Meter: 102
it can be dangerous for pcb it s better to use power supply because you dont have current limit
and use a thermal camera to detect the faulty area
The Following User Says Thank You to kham For This Useful Post:
Page generated in 0.28551 seconds with 9 queries
