Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
10-18-2004, 15:01 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: The Netherlands Age: 40
Member: 58493 Status: Offline Thanks Meter: 24 | new clip for panasonic x60 and sharp gx20/30 someone knows how to use this clip or some kind of manual? thanks in advance p.s. sorry for bad quality picture, its from a 6230 |
10-18-2004, 22:06 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: Hofburg
Member: 6845 Status: Offline Thanks Meter: 30 | For SharpGX30/TM100 clip on,phone on press midlle button on clip 1time,you will see xxxx on display,press 1,then 99,top right button on phone,3 for unlock 1 for security code,again top right button,wait till PLEASE ANY KEY will appear on display,press top right button 3times,phone turns off.Done For Sharp GX20 clip on,phone on press middle button on clip 1time,you will see diag mode,press same button again,remove battery from phone and put back(at the same time do not unplugg phone from clip),power phone and see xxxx on display,then do exactly same like for GX30.Enjoy Regards |
10-18-2004, 22:48 | #3 (permalink) | |
Member: 58493 Status: Offline Thanks Meter: 24 | Quote:
thank you! Do you also know procedure for panasonic x60? | |
10-19-2004, 00:10 | #4 (permalink) |
Member: 6845 Status: Offline Thanks Meter: 30 | As I remember from manual,clip on phone on press first button on clip from left to right,1st led starts to blink,wait untill light is on permanently and job is done obviously,but I never try it on X60.So try yourself. Regards |
10-19-2004, 00:31 | #6 (permalink) | |
Member: 6845 Status: Offline Thanks Meter: 30 | Quote:
Regards | |
10-19-2004, 00:32 | #7 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: netherlands Age: 42
Member: 50272 Status: Offline Thanks Meter: 37 | if you are interessed for this clip contact me. i have in stock.. name fo this clip hmm.. what you like ? hehe.. look here : http://gsmhardware.com/pictureexstra/Afb057.jpg http://gsmhardware.com/pictureexstra/panshow/Afb000.jpg best regards Secgsm [email protected] Quote:
10-19-2004, 18:21 | #8 (permalink) | |
[email protected] p.s. I think my reseller bought it from you, a guy from holland?? | |
10-19-2004, 22:05 | #9 (permalink) | |
Member: 50272 Status: Offline Thanks Meter: 37 | hello Gsm2Extreme, ok i will done, yes my partner sale my tools in netherlands. ok check you mail. i have now busy after 1-2 hour i will send manual by mail. best regards Secgsm [email protected] Quote:
10-20-2004, 19:55 | #10 (permalink) |
Member: 58493 Status: Offline Thanks Meter: 24 | X60 unlocking... tried 20 times... not working Gx10i unlocking... after pressin 2 times on 2nd button, phone is in diag mode... power down phone.. power on phone no XXXX showing what is te problem? i have 2 pcs. of this clip so one of them should work.. but no |
10-20-2004, 21:32 | #11 (permalink) |
Member: 50272 Status: Offline Thanks Meter: 37 | clip tested on pan. x60.. manual : http://www.gsmhardware.com/combiclipmanual.htm best regards Secgsm Last edited by Secgsm; 10-20-2004 at 23:11. |
10-21-2004, 11:19 | #12 (permalink) |
Member: 58493 Status: Offline Thanks Meter: 24 | in manual for unlocking gx10i it says: "press top right button to power off phone" that's also not working.... the only way to power down the phone is by pressing the red power button. If i then power on the phone XXXX is not showing... |
10-21-2004, 16:43 | #13 (permalink) |
Insane Poster Join Date: May 2003
Member: 29063 Status: Offline Thanks Meter: 0 | X60 instructions 1) Put 4 fully charged AA Batteries in Uni-Clip 2) Make sure the phone is off without a sim card in. 3) Put the phone into test mode by holding down the # and * key and then the power button. You will see a faint back light on the phones screen. The phone is now in test mode. 4) Connect the X60 cable to the Uni-Clip and then to the phone 5) Turn Uni-Clip on using the black switch on the side of the clip 6) Press the Uni-Clip unlock button 7) The Uni-Clips lights will turn off, 8) One light will show on Uni-Clip to indicate the unlocking process has started. 9) Then both lights will be on to show the unlocking process is completed. The phones back light will go off. The phone is now unlocked. spooneroon |
PANSOLAR, the new clip for Panasonic and much more | Raskal | Main Sales Section | 0 | 04-25-2006 21:56 |
Panasonic x70 and Sharp GX30 with new Griffin?? | UnlockBR | Griffin | 18 | 09-21-2004 07:47 |
Brand New Nokias (7600, 6610) ; Samsungs (E700, P400) and sharp GX-30 | chrisbeckett | Sell ur Old and Used Stuff | 13 | 06-08-2004 18:59 |
Bad activation Status on C62 and Sharp Gx20 | tiagomanson | Griffin | 20 | 02-15-2004 21:13 |
