Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
09-07-2017, 04:54 | #1 (permalink) |
Insane Poster Join Date: Sep 2017
Member: 2753739 Status: Offline Thanks Meter: 7 | how to use Aoyue 852A++ i bought new hot air gun Aoyue 852A++ i used it with some bad boards i have it's very quick to take chips off i put the temperature 390 Cْ and the air pressure between 65 and 55 my quistion is what i did is right or not ? help me please |
09-07-2017, 07:19 | #2 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | hi correct use on old boards to figure out how it works .. but the correct working temperature depends on the type of repair you will have to do what type of m.board you will need to repair. Anyway, 390 degrees are so many yet try to still exercise while lowering the temperature and removing small components up to the bigger ones. Temperatures are chosen by experience, check youtube is a jungle of tips and you'll see and understand who works well and who works badly. |
09-07-2017, 09:49 | #3 (permalink) |
Member: 2753739 Status: Offline Thanks Meter: 7 | i tested on some chips like tigerst and tristar they took off fast and the board not hot much my experience a little bit on this kind of hot air station thank you bro i didn't find any instuction on youtube if anyone use same this station tell me |
