JC PRO 1000S Tutorial, how to, tips and tricks JC PRO 1000s is the interface and you can add many modules 32/64 NAND hard disk read/write module Support iPhone 4 4S 5 5S 5C 6 6P Support iPad 234 Air 12 Mini 1234 JC P7 PCIE NAND read/write module Support 6S 6SP 7 7P 5SE Support iPad Pro Feature: · touch screen · Free ROTS Operating system · Support SD USB Communication · Support Chinese and English · Direct online, offline · Support APP download -most be powered with usb c mine didnt not come with internal battery -adaptor for Ipad2,3,4 only works with wifi versions Ipad 2 only works newer revision of ipad 2 -adaptor for ipad 456 works with wifi versions of ipad 4, air1 and air2 will add more information when modules arrive |
I have the P7 and the 456 Air 1/Air 2 adapter and both of them are total garbage. The P7 can't read or write to at least half of the nands I've thrown at it. The online software is full of bugs, the ipad 456 adapter can't read or write to any devices over 64gb, the build quality of the 456 adapter is horrible, the springs on mine broke within the first week, and I also have the jc pro 1000s and it has so many issues I can't even count them. Anyone thinking of buying a programmer should read as much as possible before getting invested. The JC line of modules is very appealing but if the other units are anyuthing like the junk I received I'd rarther spend the money elsewhere, |
About Toshiba nand these nand are not supported also from other programmer and the bad thing is that they are present on a good 70 percent of the iPad air and air 2 so if JC made an effort to update their software to write these toshiba would be perfect but instead like many manufacturers of similar tools develop an exceptional tool and then leave it and focus on others .. I've also NandPro and seems to support these Toshiba with adapter but this item seems unobtainable in the market so need to remove the nand. You've right bad support with the software while some their tool are good. |
2 Attachment(s) Quote:
ckeck here .. Attachment 372286 Attachment 372287 |
both are avaiable for sale on gsm**er bought a few days ago |
1 Attachment(s) Hello query. I have the JC 1000S and from one day to another I stop working, Now the software only recognizes me the USB port and does not read me any NAND, nor does it turn on any of the identification lights, blue, green or red Please someone help me. attached error photo Thank you help please Can anybody help me. It is not driver problems, everything is OK in the installation. I think the internal memory that allows reading the NAND memories was deleted |
Hi, install :assistant 1.1.99.17 |
HI, Photos above are about jc-P7 plug in computer and running with the firmware |
JC Software for PC looks like some 9yo with no skill is writing it. They'd be better off to hire a high-school intern to fix the obvious issues. Totally ridiculous. |
but for remove icloud with jc pro , for ipad, only wifi supported LTE can't be done right ? |
you need to remove resistor on ipad to make them work with jc pro |
