Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 02-06-2006, 13:34   #1 (permalink)
kades's Avatar
Member: 77651
Thanks Meter: 21
Howto write a PIC using IC-PROG
hI!
I'm a newbie writing PICs...
I'm trying to write a PIC (12F629) using IC-PROG on Win98, but when I try to check the HEX file I get a eror 000F and when I try to write the file the PIC's value is only '0000...'.
Any idea?! Is a problem with the HEX file or there is some kind of configurantion to do on IC-PROG???
Tnx.
Old 02-07-2006, 10:33   #2 (permalink)
Cheater -Don't Deal with him-
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
this will help friend thnks reply if not work
http://www.semis.demon.co.uk/Pics/PICmain.htm
Old 02-08-2006, 04:30   #3 (permalink)
Surej's Avatar
Member: 12296
Thanks Meter: 9
The ICSP based programing works fine with IC prog..There are a few schemes for that...I think the problem is with your hex may be the hex is not in the right format...which hex you are tying to write..? Contact me in any IM i'll try to help...
WBR
Surej
Old 02-09-2006, 11:35   #4 (permalink)
Member: 149135
Thanks Meter: 234
Originally Posted by kades
hI!
Tnx.
I think you whant to make a clone of SCDRII!!! PIC 12F629 is emulator for original DS(serial number digital unic... which is in original SCDRII)!! Now question
1-You try to reprogram original pic from SCDR clone V5?? Or is a new Blank Pic? Bcz if you want to program old pic is next problem..pic vas programed before whit CP(code protect) and when you program a new hex..when the ICprog whant to veryfy get error bcz canot read content(is protected)! And for this reson you get Failed at adres h00..bcz cannot read content of pic (is whit code protect)
Try to read content of PIC And you will see only 0000....but in last line i think 3F8 you will see something...this is oscilator calibrated value..you must restore after program PIC!! So my opinion is you need a PIC new blank..and a good Hardware for ICprog who is offer 13V for MCLR pin(pin4....in this pin you need 13 V for programming PIC)!!
Good Luck and send result!!
The Following User Says Thank You to djdansmart For This Useful Post:
Old 02-09-2006, 11:48   #5 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
For programing first u must erase it and after u hawe to write content to it .
U must check config so it wil work , if u don't chose good config then will never vork.
Old 02-09-2006, 22:54   #6 (permalink)
Member: 52276
Hi
try in oprtion in ic prog verify while programming and disable verify after programming.. this will help if the pic is going to be CP.
Kello
Old 02-23-2009, 11:43   #7 (permalink)
Member: 979095
Sonork: seshug22
ic programming
I m a new in PIC programming
when i programming the HEX file to PIC 16x458 through programme it show error occured at 000f, when i read it shows 0000 to all memory locations
plz give me suggessions and setting for doing programming
thank you
Old 02-23-2009, 11:48   #8 (permalink)
Member: 979095
Sonork: seshug22
thank you
plz give the reply my quarie to my gamil accoung [email protected]
thank uou
Old 02-25-2009, 16:17   #9 (permalink)
Member: 149135
Thanks Meter: 234
Which hardware you use? Best hardware for program PIC is ICD2!! But you which hardware use for program that PIC?
Old 03-02-2009, 03:35   #10 (permalink)
thushdt's Avatar
Member: 544160
Sonork: 100.1603100
Thanks Meter: 178
thank you
Hardware problem bro, use good programmer...
BR.
Old 03-02-2009, 21:50   #11 (permalink)
Member: 6358
Thanks Meter: 10
Also, if read protect is enabled in configs, sure it will read only garbage, even if it's correctly programmed.
Old 03-04-2010, 10:35   #12 (permalink)
Member: 248556
i have 16c505 pic programed i want to clone it with another 16c505 using ic-prog can anyone help me i am new to programing
Old 03-04-2010, 22:07   #13 (permalink)
Member: 149135
Thanks Meter: 234
So..read content of first IC,beware of fuse bits and then program new ic..but if is protected you cannot read it..you will read only garbage!
Old 03-04-2010, 22:23   #14 (permalink)
Member: 1055354
Thanks Meter: 252
ICD2 can NOT be used with OTP/EPROM-based old PICs like PIC16C505. The best programmer for DIL packaged PICs
(old and new) is the original PICSTART Plus by Microchip that can work directly from MPLAB.
Also ICPROG and similar crappy cheap designs are not very reliable - especially with OTP/EPROM based PICs
who require good power supply for VPP. Bad voltage VPP can result in non or partially non-working PIC
or bits toggling after some months/years and if VPP is rised too slow by cheap programmers, PIC's program
counter will increment before setting to programming mode and result of this is badly programmed PIC.
If OTP => put to trash.
Newer Flash-based PICs generate their VPP internally and just require VPP for setting into programming mode,
therefore they work better with cheap designs.
Old 03-04-2010, 22:30   #15 (permalink)
Member: 1055354
Thanks Meter: 252
A very good USB programmer for Flash-based PICs can be found here:
http://www.sprut.de/electronic/pic/p.../index.htm#b8p
I use this myself almost more often than my PICstart when i develop code and
only use the PICstart to program some old leftover OTP/EPROM PICs.
howto write in bb5 flash? tekit.dk Nokia Base Band 5 ( BB-5 ) 1 03-23-2006 20:47
What programmer to buy to use with IC-Prog? gary stonecutte Sim Cloning and Scaning 2 09-24-2004 18:30
Why I can't use IC-prog on WinXP? sir_wo Sim Cloning and Scaning 2 07-07-2004 07:52
IC-PROG doesn't write to silver card virtualj Sim Cloning and Scaning 10 07-25-2003 18:33
ic prog alrm7 Sim Cloning and Scaning 1 09-08-2002 03:50
Page generated in 0.23273 seconds with 9 queries
