Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 03-16-2017, 17:15   #1 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
Components compatibility and manufacturer's code
APPLE :
USB / CHARGE IC:
Iphone 5 (U2) CBLT1608A1
Iphone 5c (U2) CBLT1610A1
Iphone 5s (U2) CBLT1610A1
Iphone 6/6Plus (U1700 "U2") CBLT1610A2 compatibility with 1610A1
Iphone 6s/6SPlus (U4500 "U2") CBLT1610A3
Iphone SE CBLT1610A3
Iphone7/7Plus CBLT1610A3
Ipad Mini CBTL1608A1
Ipad Mini 2 CBTL1610A1
Ipad Mini 3 CBTL1610A1
Ipad Mini 4 CBTL1610A1
Ipad 4 CBTL1608A1
Ipad Air CBTL1610A1
Ipad Air 2 CBTL1610A1
Ipad PRO CBTL1610A3
Ipod Touch 5G CBTL1608A1
Ipod Touch 6G CBTL1610A2
Ipod Nano 7G CBTL1608A1
TOUCH IC :
Iphone 5 black ic (U14) 343S0628
white ic (U12) BCM5976c0kub6g
Iphone 5S/5C black ic (U15) 343S0645
white ic (U12) BCM5976c1kub6g
Iphone 6/6plus black ic (U2402) 343S0694
white ic (U2401) BCM5976C1KUB6G (compatibility with iphone 5S)
Iphone 7/7Plus
BACKLIGHT IC
Iphone 5 LM3534TMX-A1
Iphone 5C LM3534TMX-A1
Iphone 5S LM3534TMX-A1
Iphone 6 LM3534TMX-A1
Iphone 6Plus (both 2 ic's) LM3534TMX-A1
Iphone SE LM3539A1
Iphone 6S LM3539A0
Iphone 6S plus (both 2 ic's) LM3539A0
Iphone 7 LM3539A1
Iphone 7 Plus (both 2 ic's) LM3539A1
Ipod Touch 6G LM3534TMX-1
IPHONE 7 VARIOUS IC :
Wifi/Bluetooth Module IC : USI160814, 339S00201, 339S00199, LBEE5W11GJ-943
Touch ID Mesa Boost IC : LM3638A0
LED Driver Backlight IC :LM3539A1
Tigris Charger IC : SN2400AB0
Active Diode IC : CSD68827W
1st Speaker Amplifier IC : CS35L26-A1
System Power: BOOST IC : SN61280D
BaseBand Modem Processor (BB CPU) : PMB9943
Accelerometer + Gyroscope Combo IC : INVENSENSE MPU-6900
2nd Speaker Amplifier : CS35L26-A1
Compass IC : HSCDTD601A
Iphone 7 Plus
Apple A10 Fusion APL1W24 SoC + Samsung 3 GB LPDDR4 RAM (as denoted by the markings K3RG4G40MM-YGCH)
Qualcomm MDM9645M LTE Cat. 12 Modem
Skyworks 78100-20
Avago AFEM-8065 Power Amplifier Module
Avago AFEM-8055 Power Amplifier Module
Universal Scientific Industrial O1 X4
Bosch Sensortec BMP280 Barometric Pressure Sensor
Toshiba THGBX6T0T8LLFXF 128 GB NAND Flash
Murata 339S00199 Wi-Fi/Bluetooth Module
NXP 67V04 NFC Controller
Dialog 338S00225 Power Management IC
Qualcomm PMD9645 Power Management IC
Qualcomm WTR4905 Multimode LTE Transceiver
Qualcomm WTR3925 RF Transceiver
Apple/Cirrus Logic 338S00105 Audio Codec
Cirrus Logic 338S00220 Audio Amplifier(x2)
Lattice Semiconductor ICE5LP4K
Skyworks 13702-20 Diversity Receive Module
Skyworks 13703-21 Diversity Receive Module
Avago LFI630 183439
NXP 610A38 USB IC
TDK EPCOS D5315
Texas Instruments 64W0Y5P
Texas Instruments 65730A0P Power Management IC
iPhone 8 Plus
Apple 339S00439 A11 Bionic SoC layered over Samsung 3 GB LPDDR4 RAM
Qualcomm MDM9655 Snapdragon X16 LTE modem
Skyworks SkyOne SKY78140
Avago 8072JD112
P215 730N71T - likely an envelope tracking IC
Skyworks 77366-17 quad-band GSM power amplifier module
NXP 80V18 secure NFC module
Murata 339S00399 WiFi/Bluetooth module
Apple 338S00248, 338S00309 PMIC, and S3830028
SanDisk SDMPEGF12 64 GB NAND flash storage
Qualcomm WTR5975 Gigabit LTE RF transceiver and PMD9655 PMIC
NXP 1612A1—Likely an iteration of the 1610 tristar IC
Skyworks 3760 3759 1727 RF Switch and SKY762-21 207839 1731 RF Switch
IPHONE X (main components)
Apple APL1W72 A11 Bionic SoC layered over SK Hynix H9HKNNNDBMAUUR 3 GB LPDDR4x RAM
Apple 338S00341-B1 power management IC
TI 78AVZ81 battery charger
Apple 338S00248 audio codec
STB600B0
Apple 338S00306 power management IC
Apple/Murata USI 170821 339S00397 WiFi / Bluetooth module
Qualcomm WTR5975 gigabit LTE transceiver.
Qualcomm MDM9655 Snapdragon X16 LTE modem and PMD9655 PMIC. But Apple is dual-sourcing the modem, and TechInsights found an Intel XMM7480 (PMB9948) in their A1901 model. Even though the modem is capable of it, Apple isn’t supporting Gigabit speeds with the Qualcomm part.
Skyworks 78140-22 power amplifier, SKY77366-17 power amplifier, S770 6662, 3760 5418 1736
Broadcom BCM59355 wireless charging controller
NXP 80V18 PN80V NFC controller module
Broadcom AFEM-8072, MMMB power amplifier module
SAMSUNG:
Power manager (PMIC) :
I9300 (S3) / N7100 (NOTE 2) and country variants , MAX77693
I9500 /I9505 (S4) GALAXY MEGA I9200 / I9205 , PM8917
G900 (S5) and country variants , MAX77826
I9100 / I9220 (S2) , MAX8997
N7000 (NOTE 1) , MAX8997
N900 / N9005 (NOTE 3) and country variants , S2MPS11B2
N910 (NOTE 4) BIG IC , PMA8084
N910 (USB IC) SMALL IC , MAX77843
G930 VARIOUS IC :
Upper microphone ; SPH0641LM4H-1
Axis Sensor (Accelerometer/Gyroscope) IC ; K6DS3TR
Wifi/Bluetooth Module IC ; SWB-B90S, 0117S7, G317A7
NFC IC ; SEN81DGXST
Wireless Power Receiver ; P9221S
HRM Sensor ; MAX86907
Barometric Pressure Sensor IC ; LPS25HBTR
MST (Magnetic Secure Transmission) IC ; ISP7022
OVP IC this is MST related IC ; FPF2495B</li>
Rear/Front Camera Companion IC ; S5C73C3
Sub Power Management IC ; S2MPB02
Display (OLED) Power Management IC ; S2DOS03
Main AP/CP (BB) Power Management IC ;S2MPS16
ET Modulator IC ; S735
Transceiver RF IC ; Shannon 935
RF Path Switch IC ; Avago AFEM-9030
Magnetic Sensor IC ; YAS537
Hall Sensor IC ; S-5712CCDL1-I4T1U
GPS/Sensor HUB ; BCM4774IUB2G
IF PMIC,SW Charger,Motor Driver, LED driver, USB OTG, MUIC, Fuel Gauge ; MAX77854
Bottom ModAP (AP + CP) CP mean BB CPU ; EXINOS8890/Top LPDDR4-4GB ; K3RG2G20BMCGCJ
NAND Flash (AP + CP) UFS Memory ; THGBF7G8K4LBATR
Buck Booster ; S2ABB02
Speaker Amplifier IC ; MAX98506
Audio Codec IC ; CS47L91
Charging OVP/Load SW ; FPF2488
Galaxy S8(SM-G950FD) G950
MAX77865 Maxim Interface PMIC
S3NRN82 Samsung NFC Controller, w/ Secure Element
LSM6DSL STMicroelectronics 6-Axis Accelerometer+Gyroscope
BCM4774 Broadcom GNSS Receiver / Sensor Hub Combo IC, MultiConstellation, GPS / GLONASS / QZSS / SBAS /
BGSA14GN10 Infineon SP4T Antenna Tuning Switch
S-5712CCDL1 Seiko Instruments Hall Effect IC
AP7340 Diodes 150mA HIGH PSRR LOW NOISE LDO WITH ENABLE
CS47L93 Cirrus Logic Audio Codec
FAN48611 Fairchild Semiconductor 2.5 MHz, Fixed-Output, Synchronous Tiny BoostŪ Regulator
MAX98506 Maxim Class DG Audio Amplifier
S2MM005X01 Samsung USB Type-C PMIC
AK09916C AKM 3-Axis Electronic Compass
LPS22H STMicroelectronics Barometric Pressure Sensor
P9320S IDT Wireless Power Receiver
K3UH5H50MM-NGCJ Samsung SDRAM, Mobile DDR4-3733, 32G-bit, PoP
Exynos 8895 Samsung Baseband Processor, Exynos 9 Octa Core, Quad Core Exynos M2 Cores 2.3 GHz, Quad Core Cortex-A53 Cores 1.7 GHz, Mali-G71 MP20, 10nm FinFET, PoP
GALAXY S9+ G965F
Samsung 82LBXS2 NFC
Wifi Bluetooth Module
Heart Rate Sensor
Maxim MAX98512 Audio Amplifier
Samsung S2MPB02 Camera PMIC
Shannon 560 PMIC
Cirrus Logic CS47L93 Audio Codec
Samsung S2DOS05 Display Power Management IC
Shannon 965 RF Transceiver
Avago AFEM-9090 Front End Module
Skyworks SKY77365-11 Power Amplifier Module
Murata fL05B Power Amplifier Module
Shannon 735 Envelope Tracker
Samsung Exynos 9810 + Samsung 6 GB LPDDR4X (PoP)
Samsung KLUCG2K1EA-B0C1 NAND Flash
Maxim MAX77705F PMIC
Broadcom BCM47752 GNSS Receiver
IDT P9320S Wireless Charging Receiver
QUALCOMM PMIC :
PM8994 :
LG G4 H815 , H818 AND VARIANTS
HTC M9 ALL VARIANT
SONY XPERIA Z3
SONY XPERIA Z5
SOME XIAOMI
PM8941 :
SAM NOTE 3 N9005
SAM TAB325
SAM S4 I9500 VERSION (NO I9505)
SONY XPERIA Z1 / Z2
XPERIA Z3 COMPACT
HTC M8
LG G3
XIAOMI MI NOTE PRO
PM8226
SAM G710
SAM I9301I
updating...
The Following 42 Users Say Thank You to orx For This Useful Post:
Old 04-04-2017, 11:11   #2 (permalink)
Bastaphone's Avatar
Member: 385881
Thanks Meter: 40
Been searching for such a compatibility chart for long time, nice info, thanks!
Old 04-04-2017, 13:02   #3 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
-----------you are welkome-----------
Old 05-25-2017, 16:17   #4 (permalink)
Member: 1271444
Thanks Meter: 4
does anyone know backlight IC for iPod Classic 30 GB A1136?
Old 05-25-2017, 21:47   #5 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
hi
if i remember maybe is same of the iphone 4..seems this ic is not easy to found..anyway ceck backlight ic iphone 4.
If you want to replace also coil you can to use that iphone 5s is the same.
Old 06-03-2017, 09:39   #6 (permalink)
Member: 2342591
thanks for this info
The Following User Says Thank You to svpack For This Useful Post:
Old 07-22-2017, 00:50   #7 (permalink)
Member: 1581391
Sonork: firulilla
Thanks Meter: 8
very very good,,fantastic information,,thanks
Old 11-13-2017, 20:49   #8 (permalink)
Member: 2776718
Sonork: 100.1679314
POWER IC:
PM8029 : Sam SM-G7102; Sam Gear live; Nokia Lumia 730; LG Watch Urbane.
PM8226 : Sam I9505; I9515 S4 4G; I9295 S4 Active; I9190. I9192 S4 Mini; I9200 Mega.
PM8941 : Sony Z2; Sony Z3.
Sam : SM-N900; SM-N900A; SM-N900T.
Old 11-14-2017, 15:36   #9 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
I9505 , i9200 , i9192 has PM8917 no PM8226 I've changed a lot to get me wrong..please no give wrong info.
Old 04-05-2018, 14:23   #10 (permalink)
Member: 1042220
Thanks Meter: 2
Thanks for the great info.
Old 04-06-2018, 09:06   #11 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
you are welcome .
Old 06-16-2018, 00:31   #12 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
very useful info ..........!
Old 07-04-2018, 13:57   #13 (permalink)
Member: 724064
Thanks Meter: 13
thanks sir
thanks a lots its r complicated job u ve done . thanks we r greatfull to u
Old 07-06-2018, 09:18   #14 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
- you are welcome bro -
The Following User Says Thank You to orx For This Useful Post:
Old 09-21-2018, 21:42   #15 (permalink)
Member: 1418143
Thanks Meter: 353
hello,
nice work br orx
I'm going to buy and sell apple Nand chips , I'm looking a compatibility list if possible
Page generated in 0.21861 seconds with 9 queries
