Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 11-27-2011, 12:20   #76 (permalink)
Member: 240778
Thanks Meter: 3
WHEN WE INDRTAND HOW ONE COMPONENT WORK IT.S EASY TO CECH HIM.FOR EXEMPLE RISESTOR OR BOBINE.ACCORDING OF OHM V=R*I AND R=V/I .BUT IN BOBINE IMPEDANCE IS Lw*I WHERE w=2P*f (p=3.14 and f =frequency) to know more of all componant give you abilite to resolve problems.
Old 12-03-2011, 17:55   #77 (permalink)
Member: 1627353
Sonork: TWISTER 93179
Thanks Meter: 3
hello with much glad to u.
pls i may need an asistment from u , if only u care i;m a jonior member i'm in great distress pls i need u to help me out, pls y. i'll be glad to meet u on line pls . when was that? this my email,,,,,[email protected] i' l apreciate ur understanding and ur little time . to meet u .pls accept my invitation .
my regards to all gssforum members and
administrators ''
thanksssss
Old 01-06-2012, 17:01   #78 (permalink)
Member: 1365226
Thanks Meter: 19
Originally Posted by leonard devinci View Post
Mobile phone Camponement ( Resistor , Condasator , Diode ) must be desolder before Measured , or it can to be measured even it's solder on board ?
if componenets have other in parallel they measured by removing one of them
if they have' nt you can test them on board
if they are in parallel with IC do not put the positive probe in the ground, when measuring for example resistors
you need also to remove components when you need to check for shortin in the PCB , for example remove coil that are in serie with IC's to know if it cause the shorting
Old 09-04-2012, 08:06   #79 (permalink)
Member: 687718
Sonork: 100.1603913
Thanks Meter: 121
Hi all
i am using this (positive probe on ground) method since 2004. And i repair thousands of sets by this method. I have made own theory about it but my problem is i dont know english very well so i am unable to translate my theory for you guys.
If any indian people need this theory in hindi language can contact me on 09907432714
Old 09-15-2012, 13:01   #80 (permalink)
Member: 1802236
I wanted to say thanks for the info, I'm a self starter and I love doing this type of work. Started as a hobby and I'm trying to make it full time. Not sure how to do the thanks box.
Old 11-27-2012, 20:05   #81 (permalink)
Member: 1365226
Thanks Meter: 19
Originally Posted by manishavar15 View Post
Hi all
Can you post your theory or give download link please?We can translate it with translater software, Thanks in advance!!
Old 11-27-2012, 20:09   #82 (permalink)
Member: 1365226
Thanks Meter: 19
Originally Posted by diehard View Post
Yashtel, you are right about this. But usually it's better to use diode measuring function on multimeter, because you test ESD protection diodes inside some IC. This way it's possible to check many IC input/output connecion. data or address bus.. But still osciloscope is essential equipment.
With diode test you will not get reading in case of high forward voltage diodes so using ohm meter is better
Old 01-08-2015, 11:00   #83 (permalink)
Member: 102582
Thanks Meter: 72
"When We Change The Keypad Ic Either It Is Correctly Fitted Or Not I Have To Check By Putting The Lcd Back Body And Battery And On The Set With Sim Check The Keypad And Joy Stick."
Kindly elaborate with possible image or manual diagram for more clarity ?
Awaiting for your good job ?
Thanks,
BR,
amit123
Old 03-17-2019, 10:55   #84 (permalink)
Member: 653038
Thanks Meter: 9
this information is usefull for all friends thank brother
Old 07-18-2023, 13:49   #85 (permalink)
Member: 2602888
Sonork: Not Using
Thanks Meter: 2
Originally Posted by yashtel View Post
As We Measure By Taking Negative Probe To The Ground And Positive Probe To The Position Where We Have To Measure While In Voltage, But In Case Of Ohms (contunity Test Or Track Check) We Measure From The Receive Point To Target Point
Maximum Cases There Are Track Brocken Which We Don't Know The Source Point Even Many Track Are From Below The Ic Where Our Multimeter Probe Dosen't Reach
So My Solution Is That We Will Measure The Point By Taking The Positive Probe To The Ground And Negative Probe To The Target Point There Will Be A Value Shown In A Ohms Range We Must Note It From Good Set
Thanks for the technique man, really helpful for me.
FPS-10, SX4 and other original Nokia Equipment GsmProf Sell ur Old and Used Stuff 4 04-09-2008 15:47
New way to find pinout solution - Hope it will help other members GuruKids Infinity-Box 7 01-06-2008 09:41
The correct ways to unlock W810, W800 and other?? dynamic-gsm HWK 2 11-19-2007 12:49
How to flash V360 ,l6 ,and other new models without tp?? basim Motorola P2k 3 10-25-2006 02:15
...::: New online update server and new way to enter Support Area :::... zulea Phoenix Black Box 46 01-04-2006 13:27
Page generated in 0.29309 seconds with 10 queries
