Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
View Poll Results: we must have an oscilloscope to repair hardware
yes 1,117 72.39%
no 437 28.32%
Multiple Choice Poll. Voters: 1543. You may not vote on this poll
Old 10-10-2009, 19:13   #136 (permalink)
Member: 542244
Thanks Meter: 4
Originally Posted by ichal_spy View Post
i have sample for my tutorial repair signal problem..
the problem is... the languange is indonesian...
is it ok???
if ok ill upload it
we waits?
Old 10-31-2009, 16:10   #137 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
Originally Posted by BraveNewWorld View Post
Oscilloscope is for fixing tv's.
oscilloscope can be used in servicing any electronic equipment if you know how to use it and have service manual of equipment need servicing.
Old 10-31-2009, 17:01   #138 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
Question
is it ok???
if ok ill upload it
hi do you have service manual i need tutorial repair signal & problem.. how to find pls help me
Old 10-31-2009, 21:34   #139 (permalink)
Rizal Arsyad Dini's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 6,201
just read nokia service manual level 3
u can get some info there
tq
The Following 2 Users Say Thank You to Rizal Arsyad Dini For This Useful Post:
Old 11-24-2009, 20:51   #140 (permalink)
Member: 675260
Thanks Meter: 30
Please oscilloscope for professional maintenance
Enough that Nokia used this device
Dear genius How will you know that the b2200 32.768 khz Relating to ic avilma Working or not !!!!!!!!!!!!!!!!!
oscilloscope for PRO.......
Old 12-02-2009, 01:07   #141 (permalink)
Member: 20500
Thanks Meter: 4
is it ok???
if ok ill upload it
ok ichal spy
any langauge and we can translate to any lang by using google translate
and we all know well elictronic languge
thaks for help
Old 12-02-2009, 01:10   #142 (permalink)
Member: 20500
Thanks Meter: 4
@ ichal spy
pleas i nead you to exxpain some pwoer fualts using frequncy counter
and make it from a to z
thanks again
Old 12-09-2009, 08:53   #143 (permalink)
Member: 392792
Sonork: lasa_dal
Thanks Meter: 8
oscilloscope can be helpful . but mostly worthless when U R dealing with ded set or without diagrams. and there are few things uU can do with oscilloscope. the Idal thing should be CMU 200 .
Originally Posted by pkghosh1 View Post
which is the best Hardware Equipments to masure short bord or dead set or
bb5 handset problem?can we must have an oscilloscope for best repair?
Old 12-09-2009, 08:58   #144 (permalink)
Member: 392792
Sonork: lasa_dal
Thanks Meter: 8
U cannot mesure it with oscilloscope, coz oscilloscope can mesure max 40MHz.
use spactrum analyzer or CMU200, or just replace it ( its better)
Old 12-11-2009, 01:27   #145 (permalink)
Member: 39251
Sonork: 100.1618715
Thanks Meter: 6,201
wrong dear....
we can check it with osciloscope... i always check it .. and when u check it witch osci u will see like this pict...
Old 12-22-2009, 00:04   #146 (permalink)
Member: 44625
Thanks Meter: 36
@lasa_dal,
The crystal frequency is in Kilohertz (32.768 KHz) and not in Megahertz. So the oscilloscope CAN measure it. This could also be checked on a multimeter with a frequency counter function or a stand alone frequency counter. I once was lucky to get a multimeter that goes upto 14MHz.
Old 01-17-2010, 17:04   #147 (permalink)
Crazy Poster
Member: 1192716
Sonork: Lucnow
Thanks Meter: 5
i want purchase new oscilloscope or*spectrum analizer kaun sa better hai please give model no. thanks
Old 01-17-2010, 17:40   #148 (permalink)
blueteamgsm's Avatar
Member: 564247
Thanks Meter: 34
I add from :
Gsm power meter to check signal power , very useful.
Old 01-31-2010, 06:00   #149 (permalink)
=GsM_Angel='s Avatar
Member: 1062107
Thanks Meter: 544
that's good for measuring frequencies.. but still your hardware abilities and skills is the best tools......
Old 01-31-2010, 11:35   #150 (permalink)
Member: 325999
Thanks Meter: 113
All branded test equipments r costly for mobile repair shop if any china company (GPG,IPMART) made some test equipment specially for mobile repair shop ,that will be HOT product for us.
REGARDS
Which is the best gsm field to Work??? sallu GSM Programming & Reverse Engineering 8 03-22-2007 07:14
what is the best route to buying cdma equipment jesto80 Various CDMA/TDMA Cell Phones 1 03-13-2007 04:01
HackGSM web site updated. Jouin Us for the best GSM equipment and price for it! hackgsm.net Main Sales Section 0 03-27-2005 11:59
All the best GSM Hardware devices! stargsm Main Sales Section 0 03-11-2003 19:53
Page generated in 0.20463 seconds with 11 queries
