Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
View Poll Results: we must have an oscilloscope to repair hardware
yes 1,120 72.40%
no 438 28.31%
Multiple Choice Poll. Voters: 1547. You may not vote on this poll
Old 02-10-2010, 05:24   #151 (permalink)
Member: 88097
Thanks Meter: 3
scope
only used for finding broken prints or for jumpering on pcp
Old 03-14-2010, 10:02   #152 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 235
Question
Originally Posted by ichal_spy View Post
just read nokia service manual level 3
u can get some info there
tq
hi sir i need you help me you wright her ust read nokia service manual level 3 u can get some info there my qus is wher i find out the service manual level 3 sir if you have then upload pls sir
Old 03-15-2010, 09:05   #153 (permalink)
ibrajinja's Avatar
Member: 562975
Sonork: better tomorow
Thanks Meter: 250
is there no professional to make conclusion on this topic so as to gueid us on this topic.
The Following User Says Thank You to ibrajinja For This Useful Post:
Old 03-15-2010, 19:15   #154 (permalink)
hassanjinja's Avatar
Member: 126167
Sonork: 100.1591387
Thanks Meter: 5,129
Talking fault finder
Hi,
Any Basics , have u got ?.
HASSAN
Old 03-23-2010, 07:52   #155 (permalink)
Member: 1268228
guys ..
i am new in this streem...
doing some 6 month collage project work in telecom (based on GSM) company...
i know basics of GSM network elements... interfaces.. and call process and hoppings.. blahh...
now i want know about mobile hardware.. i am a electronic and instrumentation engineer .... can someone help me with their basics..and i have a nokia 3110c (lol) mobile with me...
thankyou
Old 03-23-2010, 16:38   #156 (permalink)
Member: 22542
Sonork: 100.1660285
Thanks Meter: 103
whats wrong with your 3110C
Originally Posted by asokraju View Post
guys ..
thankyou
through this forum it can be easy to assist someone with specific problem not general knowledge about phone we normally share experience of problem solving e.t.c
The Following User Says Thank You to benny Haraba For This Useful Post:
Old 04-07-2010, 06:43   #157 (permalink)
Member: 1113899
Thanks Meter: 39
digitel multi meater supply
frequency mearer
and aynalog multi meater
this Equipments are all the problim diefaine to your gsm setes
but the oscilloscope is very expencive tool
Old 04-08-2010, 08:08   #158 (permalink)
Member: 161114
Thanks Meter: 4
Thumbs up osciloscope
The use of the osciloscope device is to measure the signals or frequency( cycle per seconds).
For that first we should know the points on pcb where we can put the probe of scope. ( for example. Input of audio ic is digital and output should be analog in the matter of rx simillarly in tx input should be analog and output should be digital so the parts where the input is coming, and where the output is coming from ic that location should be know well).
Secondly we should know the normal waveforms at that particular points.
So better to use multimeter and ohms concept in it.
As per my knowledge 900mhz / 1800mhz means its very high range. So the scope will also expensive.
The Following User Says Thank You to bhaju2002 For This Useful Post:
Old 04-30-2010, 15:21   #159 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 347
i use this and 100% of my brain i don't need oscilloscopes and result is 98% repaired phones
Old 05-18-2010, 21:53   #160 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 197
These two are the best , u can use them, if u use ur brain too , else u can't even with osciloscope and special mesuring tools .
Old 05-18-2010, 22:26   #161 (permalink)
Member: 757672
Sonork: 1575834
Thanks Meter: 34
Originally Posted by pkghosh1 View Post
which is the best Hardware Equipments to masure short bord or dead set or
bb5 handset problem?can we must have an oscilloscope for best repair?
scilloscope measures the frequencies emerging from PCP, such as
1- sleepclock oscillator
2- RF CLK
3- Network Frequency
This is the device of the best Alohzh in these measurements and less expensive for the rest of the bodies responsible. There are types of measuring up to 4 GB.
Be careful. The device has nothing to do shorts measuring device
Old 06-11-2010, 00:23   #162 (permalink)
Member: 188807
Good trouble shooting required ever oscilloscope, frequency counter, AVO meter, schematic diagrams. Then there no any fault can hidden.
Old 06-11-2010, 00:27   #163 (permalink)
Member: 188807
If you do not have oscilloscope you can not watch any oscillations in mobiles, then you don't know about pulses in cells.
Old 07-12-2010, 02:25   #164 (permalink)
AlfskieCoder's Avatar
Member: 1225453
Thanks Meter: 501
Oscilscope is the best Equipment used Specially in Repairing TV and Now Leader Oscilloscope is also best in Mobile Phones...
Old 07-12-2010, 02:28   #165 (permalink)
Member: 1225453
Thanks Meter: 501
Your Tester is FAKE..SUNWA..made in China,,I'll use SANWA Made in Jpan..YX-360TRF Model..and Your Digital Multi tester is not also good..if you use Fluke Brand and then I'll agree.... you'll have a good Equipment..hehehehe
no regards
Which is the best gsm field to Work??? sallu GSM Programming & Reverse Engineering 8 03-22-2007 07:14
what is the best route to buying cdma equipment jesto80 Various CDMA/TDMA Cell Phones 1 03-13-2007 04:01
HackGSM web site updated. Jouin Us for the best GSM equipment and price for it! hackgsm.net Main Sales Section 0 03-27-2005 11:59
All the best GSM Hardware devices! stargsm Main Sales Section 0 03-11-2003 19:53
Page generated in 0.23270 seconds with 11 queries
