Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
View Poll Results: we must have an oscilloscope to repair hardware
yes 1,117 72.39%
no 437 28.32%
Multiple Choice Poll. Voters: 1543. You may not vote on this poll
Old 08-19-2010, 10:15   #181 (permalink)
Rizal Arsyad Dini's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 6,171
Originally Posted by mobidoc View Post
hello m8s
oscilloscope is the best tool for acurate measure of signals or even dc voltages & most used in baseband repair also can be used in
rf field to check rf clock , I/Q signals & rfbus signals from cpu to rf asic .
in mobiles phones it has no limit of use :
1- u can measure crystals activity ( frequency & output amplitude to be sure of exact needed output )
2- u can measure signals of busses between ics ( rfbus & cbus)
3- u can check i2c lines activity to check faults like camera faults
4- u can check signals where pull up resitances found so u can see signals & check pull up validity
5- u can check ram , flash & sleep clocks to solve freezing & restarting problems
6- u can check smps clock used to drive the light ics
7- u can check clock & data lines of mmc
8- u can check bluetooth , gps & wlan busses signals & clocks
& much more
so we can say that oscilloscope is an important tool to work poffesionaly in gsm handsets repair field
kind regards
very nice explain bro.....
agree with u
The Following User Says Thank You to Rizal Arsyad Dini For This Useful Post:
Old 09-01-2010, 19:28   #182 (permalink)
Member: 1378486
i have n86 phone charging problem.i need help pls thanks
Old 09-01-2010, 19:29   #183 (permalink)
Member: 1378486
i need board n86 charging problem.i need daigram thanks
Old 09-01-2010, 19:30   #184 (permalink)
Member: 1378486
pls reply soon on my id [email protected]
Old 09-16-2010, 04:31   #185 (permalink)
Member: 39251
Sonork: 100.1618715
Thanks Meter: 6,171
sir... can u make new thread at nokia hardware section????
u make this thread bad!
Old 09-28-2010, 18:50   #186 (permalink)
Member: 1371990
i have work diffrent filds of electronices from my experience oscilloscope is the best fault finding instruments for all the electronices divices as you can very easyly check all
kind of signals & pulses
Old 10-18-2010, 17:24   #187 (permalink)
Member: 1365226
Thanks Meter: 19
Hello for everybody,I have some questions:
1-What is the difference between Spectrum Analyzer and Oscilloscope?
Is the difference in the frequency?Can we measure with oscilloscope the output signal
than come to antenna ? Help me please
2-Can we measure the non direct signal like clock signal without Oscilloscope?
3-What type oscilloscope and Spectrum Analyzer that are useful for Gsm Measurement?
4-I found in the net an oscillscope that is named "PoScope Basic", is it useful for Gsm Measurement?
Old 10-18-2010, 20:31   #188 (permalink)
Member: 7327
Thanks Meter: 12
hello m8
1 - Spectrum analyzer - Wikipedia, the free encyclopedia
Oscilloscope - Wikipedia, the free encyclopedia
2- if u mean clock like 32khz yes u can use frequency counter but u cant measure the amplitude of the signal .
3- digital oscilloscope with 200mhz bandwidth will be ok for baseband
spectrum analizer must be used with an rf generator to inject signal to mobile ,
3 ghz analizer & rf generator will cover all mobiles bands.
4- put link to check the specifications of poscope basic to advice u.
kind regards
The Following User Says Thank You to mobidoc For This Useful Post:
Old 10-20-2010, 17:02   #189 (permalink)
Member: 1365226
Thanks Meter: 19
Hello,can we inject RF signal from base satation without RF generator?
Old 10-21-2010, 20:10   #190 (permalink)
Member: 396575
Thanks Meter: 65
i think following istrument are useful
1-multimetre
2-kawia
3-heat gun
4-automatic power supply
5-computer
6-sw devices ex..ufs...spiderman....infiniry box.....etc
7-osciloscop .........not must
Old 10-24-2010, 08:18   #191 (permalink)
Member: 7327
Thanks Meter: 12
hello m8
about injecting signals into mobile u have 2 cases :
1st using rf generator where signal will be analog modulated with offset 67.710 khz signal but in this case u need a control software for the mobile brand ur making tests on ( like phoenix for nokia )
2nd using a gsm tester or normal gsm signal , in this case u need sim inside the mobile while making manual search ull be able to measure i/q sgnals , pulses & rf control voltages .
here is an example posted by me here YouTube - 19042010003.mp4
kind regards
Old 11-05-2010, 20:32   #192 (permalink)
Member: 479593
any buddy tell me
any saler ossiloscope and infrared
in india
and best quality mobile spare parts,flax dealer
Old 11-08-2010, 19:24   #193 (permalink)
AlfskieCoder's Avatar
Member: 1225453
Thanks Meter: 501
ossiloscope is best in Audio and Video Servicing
-For Advance Communication is Very Best Too
Old 12-12-2010, 22:24   #194 (permalink)
Member: 1445395
Thanks Meter: 2
Hello Isac Spy
I followed your activities here.AND you looks like a prof in this area .And i would like to ask your opinion about the next instrument.Do you think this could be usefull among in my developing gsm skills supporter instrument?
USB Function Generator/Oscilloscope i think so this sampler is can not work in real time but has a very wide capabilities up to 4 GHZ SO MY QUESTION IS ? What is your opinion about this usb digital oscilloscope in gsm related servicing.Thank you very much your answer in advance.
Old 12-13-2010, 09:21   #195 (permalink)
OTIENOJULIUS's Avatar
Member: 898387
Sonork: 1000.2
Thanks Meter: 103
rework station,multimeter,......etc oscilloscopes is too x pensive 4 nothing
Which is the best gsm field to Work??? sallu GSM Programming & Reverse Engineering 8 03-22-2007 07:14
what is the best route to buying cdma equipment jesto80 Various CDMA/TDMA Cell Phones 1 03-13-2007 04:01
HackGSM web site updated. Jouin Us for the best GSM equipment and price for it! hackgsm.net Main Sales Section 0 03-27-2005 11:59
All the best GSM Hardware devices! stargsm Main Sales Section 0 03-11-2003 19:53
Page generated in 1.25530 seconds with 11 queries
