Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
View Poll Results: we must have an oscilloscope to repair hardware
yes 1,120 72.40%
no 438 28.31%
Multiple Choice Poll. Voters: 1547. You may not vote on this poll
Old 07-04-2008, 08:34   #16 (permalink)
yousaf22us's Avatar
Member: 113943
Thanks Meter: 73
oscilloscop is only best for those modelz if u have already configuration of wave length table for measuring for frequency at any point with out measuring table of any board dont think so its useful
The Following 2 Users Say Thank You to yousaf22us For This Useful Post:
Old 07-04-2008, 09:18   #17 (permalink)
Member: 17800
Thanks Meter: 8
nokia screwdriver is the best tool
The Following 2 Users Say Thank You to r-o-y For This Useful Post:
Old 07-04-2008, 09:44   #18 (permalink)
Member: 4875
Thanks Meter: 9
depends - the freq the osciloscope can measure and if it is analogic or digital or if it has memory or not to save the readings. If u have a osciloscope that can measure 2 GHz frecvency then is good for GSM. lower frectvency rate osciloscopes doesen't helpo very much but is good for measure the TX and RX or the clock ... Spectrum analyser is a diferent tool there u can see not the form of the wave but the range and the amplitude and the armonics wich does help some time. But the best tool is brain and electronic knowledge and a vrey good multimeter. Of course a very good power supply also is good but we must not forget that the best is the hot or air infrared soldering reworking tool. But again depends on the fault that we must solve. If it is a software problem then the box and the software can make all the diferences. Best regards u all. alianu.
The Following 4 Users Say Thank You to alianu For This Useful Post:
Old 07-05-2008, 06:33   #19 (permalink)
torpedo_seluler's Avatar
Member: 368629
Thanks Meter: 87
If For Nokia we still Have to use phoenix and test jig. I think it's not neccesary.
Just use HWK do selltest. It's also quite nice solutions.
The Following 2 Users Say Thank You to torpedo_seluler For This Useful Post:
Old 07-05-2008, 06:48   #20 (permalink)
Member: 631879
Thanks Meter: 29
in jaf also we can use selftest 60-80% accuracy in hardware fault finding. .
The Following User Says Thank You to ece_05 For This Useful Post:
Old 07-05-2008, 07:24   #21 (permalink)
Member: 142949
Thanks Meter: 71
l think oscilloscope can see tx (pinout chines) and rx nead tx
The Following 2 Users Say Thank You to nguyenhuu For This Useful Post:
Old 07-05-2008, 07:37   #22 (permalink)
Member: 142949
Thanks Meter: 71
oscilloscope is champion to repair
now l sometime repair so l dont use it
The Following User Says Thank You to nguyenhuu For This Useful Post:
Old 07-21-2008, 08:18   #23 (permalink)
Member: 818748
Sonork: 00000
Thanks Meter: 44
we use osciloccope,if our service repair shop is level 4
The Following User Says Thank You to edwin08 For This Useful Post:
Old 07-29-2008, 17:46   #24 (permalink)
Member: 818748
Sonork: 00000
Thanks Meter: 44
yes!!! if your repair center is level 3 or 4,,,,vey important to use the oscilloscope and gonogo test,,,spectrum analyzer,and also the zevac machine to remove the bga ic,,,,
The Following 2 Users Say Thank You to edwin08 For This Useful Post:
Old 07-29-2008, 17:48   #25 (permalink)
Member: 818748
Sonork: 00000
Thanks Meter: 44
the best tool is the anti---static tools,,,
Old 07-30-2008, 06:02   #26 (permalink)
Registered User
Member: 684475
Thanks Meter: 13
it is better to use oscilloscope than to make error
The Following 2 Users Say Thank You to l3o_gsm For This Useful Post:
Old 08-08-2008, 14:04   #27 (permalink)
Member: 616091
Thanks Meter: 27
i think.. SELFTEST + SCHEMATICS DIAGRAM + MULTITESTER more faster and better for finding fault. and absolutly cheaper..
OSC <= efective for development only.
The Following 3 Users Say Thank You to cxacxa For This Useful Post:
Old 08-09-2008, 09:28   #28 (permalink)
Member: 218793
Thanks Meter: 29
how can we selftest? if set is dead
The Following User Says Thank You to syedqurat For This Useful Post:
Old 08-09-2008, 19:27   #29 (permalink)
Rizal Arsyad Dini's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 6,260
i have use osciloscope since 2004 and for me this tool is very important.. that make me work more focus and more easy to find the problem on the harware mobile fault
The Following 2 Users Say Thank You to Rizal Arsyad Dini For This Useful Post:
Old 08-10-2008, 16:10   #30 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
I have one.I use it only on dead phones to measure 32.678khz and 26 Mhz frequency.
The Following 2 Users Say Thank You to baldev For This Useful Post:
Which is the best gsm field to Work??? sallu GSM Programming & Reverse Engineering 8 03-22-2007 07:14
what is the best route to buying cdma equipment jesto80 Various CDMA/TDMA Cell Phones 1 03-13-2007 04:01
HackGSM web site updated. Jouin Us for the best GSM equipment and price for it! hackgsm.net Main Sales Section 0 03-27-2005 11:59
All the best GSM Hardware devices! stargsm Main Sales Section 0 03-11-2003 19:53
Page generated in 0.14869 seconds with 11 queries
