Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
View Poll Results: we must have an oscilloscope to repair hardware | |||
yes | ![]() ![]() ![]() ![]() | 1,120 | 72.40% |
no | ![]() ![]() ![]() ![]() | 438 | 28.31% |
Multiple Choice Poll. Voters: 1547. You may not vote on this poll |
![]() | #32 (permalink) |
Junior Member Join Date: Aug 2008
Member: 846837 Status: Offline Thanks Meter: 1 | I think a big rock is the most important diagnostic tool. turn the unit on,if it appears dead or not working properly,smash it with the rock to be sure it's really dead and go buy a new one...lol ![]() |
The Following User Says Thank You to darkk For This Useful Post: |
![]() | #33 (permalink) |
Junior Member ![]() ![]() Join Date: Apr 2008
Member: 749912 Status: Offline Thanks Meter: 3 | plis i know we are talking about hardware equipment but plis i av this problem that need quik answer.plis i av nokia 6060 display localmode i try to check what the problem but the phone refuse to power again. i dont know whether the problem has been rectify or not plis anybody withsolution.especially shankarbrd any solution from you. |
The Following User Says Thank You to acxton2002 For This Useful Post: |
![]() | #34 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: Java Age: 47
Member: 166000 Status: Offline Thanks Meter: 26 | If u have an oscilloscope, it can make easier for troubleshooting. But it's not a must, many ways to troubleshooting hardware problem. The best if we can combine the use of oscilloscope, multi tester, frequency counter or so on. ![]() |
The Following User Says Thank You to y2y For This Useful Post: |
![]() | #35 (permalink) | |
Member: 166000 Status: Offline Thanks Meter: 26 | Quote:
![]() | #36 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | Has anyone tried using the Magian mobile tester? IP mart used to sell it. It can check RF, pulses n continuity. It can check even very short duration pulses that only high frequency oscilloscopes and spectrum analysers can. |
The Following User Says Thank You to Trion For This Useful Post: |
![]() | #37 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2003 Location: Indonesia Age: 46
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,260 | Osciloscope funtion not only to check signal.. But for all hardware problem..... Regards |
The Following User Says Thank You to Rizal Arsyad Dini For This Useful Post: |
![]() | #38 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2001 Location: England Age: 42
Member: 7653 Status: Offline Thanks Meter: 823 | My company just purchased a Tektronix TDS2004B scope, its really a nice piece of equipment! http://uk.farnell.com/jsp/level5/mod...ml&sku=1225084 |
The Following User Says Thank You to Dave.W For This Useful Post: |
![]() | #39 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2008 Location: lincolnshire-uk
Member: 792073 Status: Offline Sonork: perelectro Thanks Meter: 25 | hi guys well for me the best equipment for repairing or service for mobile phones is those professional testing softwares that can test and tell you were is the problem not because ist easy but just think if you have 20 mobiles to repair and you know that always the customer is on hurry |
The Following User Says Thank You to henrypereira For This Useful Post: |
![]() | #40 (permalink) |
Major Poster ![]() ![]() Join Date: Apr 2005 Age: 48
Member: 139199 Status: Offline Thanks Meter: 5 | pls i have one but idont know how i use it at the mobile board i wach any bady help me about use it thankes all |
The Following User Says Thank You to na3im For This Useful Post: |
![]() | #41 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: In a point from Universe! Age: 41
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | It's right: oscilloscope can be used to measure 32.678 KHz(it can measure the frequency level);it can do a lot of things in gsm but you must know to work with such a good tool.I'm using oscilloscope since 2002 and I prefer all tools to be analogical not digital.For me are the best.By the way,I know peoples that works in gsm service but doesn't know the difference beetwen a diodde and a varistor,termistor,fuse...and others;that persons they'll gone say:A oscilloscope it's not good for gsm.My vote is for using a oscilloscope and every gsm service must have a such tool; Regards! |
The Following User Says Thank You to Burebista For This Useful Post: |
![]() | #42 (permalink) |
Member: 792073 Status: Offline Sonork: perelectro Thanks Meter: 25 | if some one use an multemeter wich include frequency meter as well as capacitor meter that equipment will do wonders on the gsm repairing . but you still have to work with the diagrams as well as knowing the values of te componet that you are measuring . beter way is having your hands on it |
![]() | #44 (permalink) |
Member: 792073 Status: Offline Sonork: perelectro Thanks Meter: 25 | here am going to give a litle tutorial how to use an oscilloscope. first you loock at your front panel, you are going to see variables saying ch that is the chanel that you connect the probes, then you loock at the screen you are going to see squares that is your scale. so let start let say that you pretent to measure a sinusoidal wave with a frequency of 5hz of 5v that you connect to ch1. now you put your vpd variable (wich is volts per division ) at 1 and nou you have to determine the time by using the formulae t=1:f you are going to know in secounds the time that you are going ti set your tpd (time per division). for instance in our example t=1:5. so you loock at your screen and your wave will be at 5 division heighbecause if yopu remember you put ai 1 vot per division ,and 0.2 secounds you put as well as 100ms per division your wave will be at 2division with .if ypou didint andertood please tell me |
![]() | #45 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2006 Location: Indonesia
Member: 368629 Status: Offline Thanks Meter: 87 | Multimeter with Capacitance Meassurement that is very useful for GMS Mobile repairing.. And Flasher Box also will be very great for testing phone |
The Following User Says Thank You to torpedo_seluler For This Useful Post: |
Which is the best gsm field to Work??? | sallu | GSM Programming & Reverse Engineering | 8 | 03-22-2007 07:14 |
what is the best route to buying cdma equipment | jesto80 | Various CDMA/TDMA Cell Phones | 1 | 03-13-2007 04:01 |
HackGSM web site updated. Jouin Us for the best GSM equipment and price for it! | hackgsm.net | Main Sales Section | 0 | 03-27-2005 11:59 |
All the best GSM Hardware devices! | stargsm | Main Sales Section | 0 | 03-11-2003 19:53 |
