Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SwS Team Products > Redbox
Old 04-01-2006, 16:02   #1 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
Arrow Post all REDBOX bugs here !!
As i see there, some bug are on RedBox , and support Team can't buy all phone with all versions in market to fix all problems,so if you need your RedBox can unlock and Flash all your mobiles
just Post bugs here :
Put all the bugs well detailled, with :
1- version for mobile, type, and all details possible , like country / provider lock
2- version of software ( redbox ) used
3- make screen shot
and all will be fixed as soon as possible
Please note for all who say bad words inside Thread will be automatic deleted so pleas be surieus and
posting detailed bugs ==> have good support ==> result good update
wbr
hitibiti
Old 04-01-2006, 16:22   #2 (permalink)
LOUAI2005's Avatar
Member: 192230
Thanks Meter: 106
hi ..........................
hard or soft
Old 04-01-2006, 16:22   #3 (permalink)
Member: 6321
Thanks Meter: 1,665
Good idea
also
http://forum.gsmhosting.com/vbb/showthread.php?t=282156
all flash possible needed for make perfect support
Old 04-01-2006, 16:36   #4 (permalink)
julvir's Avatar
Member: 3173
Sonork: 100.100
Thanks Meter: 17,098
hard or soft
All is welcome ,
but about hardware , Redbox2+ v4,7 coming , and i hope no more bugs and well protected from users and computers
but all is welcome
Old 04-01-2006, 17:10   #5 (permalink)
CrKdz13's Avatar
Member: 111121
Sonork: 100.99340 : CrKdz13
Thanks Meter: 487
SWS-Lg Comander V4.0 not work !
Old 04-01-2006, 17:13   #6 (permalink)
eko
eko's Avatar
Member: 30098
Thanks Meter: 29
What do you mean not working???.
Cant open exe??
Cant unlock???
Old 04-01-2006, 17:22   #7 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
hard to unlock e606 this days
Old 04-01-2006, 17:53   #8 (permalink)
Mounir's Avatar
Member: 58969
Thanks Meter: 56
with redbox2+ too SWS-Lg Comander V4.0 not work
Old 04-01-2006, 19:05   #9 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
we sayed that you have to give more detailed info about the problem
br
<= The_Gorr =>
Old 04-02-2006, 15:03   #10 (permalink)
julvir's Avatar
Member: 3173
Sonork: 100.100
Cant open exe??
Cant unlock???
Eko for you work right ?
because me on my 4 pc test , is working
for all i explain how we make when release a new update :
1- make beta test internal version for test on some phones ( when possible )
2- Make real version , but internal testing , here in office 4 PC + 4 PC in developpement department , winXP SP1, winXP SP2,winXP SP2 bi-procs,winXP SP2 pintiumD dualcore, Win ME , Win NT , Win 98 , and i test also on my Win Server 2003
if here all work
then we put the update online
but on our computer 99% of soft work , we have installed it very well and no virus inside etc .. also all DLL and OCX are present ! etc ..
so when you test and say not working
i need more info about your OS etc ..
if you do it well , we will also do it well
what system ...
Old 04-02-2006, 17:06   #11 (permalink)
LOUAI2005's Avatar
Member: 192230
Thanks Meter: 106
box not connected
HI ............................
REDBOX 2 box not connected
probleme hard??????
please solution
Old 04-02-2006, 18:41   #12 (permalink)
The_Gorr's Avatar
Member: 145648
check your usb connexion, don't use usb hub...
also try to disconnect any other device using usb port and try again...
br
<= The_Gorr =>
probleme hard??????
please solution
Old 04-02-2006, 19:01   #13 (permalink)
julvir's Avatar
Member: 3173
Sonork: 100.100
Arrow
probleme hard??????
please solution
This is Hardware problem,
About hardware you can read in many thread my answer :
- IMPOSSIBLE to change your Hardware remotly , so , you can change box with your local resseler ,
- Also , REDBOX2+ is avaible on stock here , and most of my Distributor have some stock too, for 50 euros + Posting Charge you can exchange your old bow hardware , redbox1 redbox2 to redbox2+
But also , becarefull because i receive some boxes at office, and boxes was working perfectly but juste because you use Bad quality LPT cable , or becuase your laptop have gestion of USB different , then your box can not work properly
about HUB , You can use HUB , why :
- USB from computer give 5V 100mA if you not delecare to your computer if you need more or not => in redbox actualy is like this !
- USB HUB declare ( say ) to windows i need more , then some time this help redbox to work on laptop who no deliver enough power ...
each day , we work on better hardware ,
exemple , one redbox was die because of electicity static from pull-over !!! when owner deconnect the LPT , for you is uncredible for me too , but now in redbox 2+V4,7 PCB some protection was added against all this
julvir
Old 04-02-2006, 22:08   #14 (permalink)
CONTACT-GSM's Avatar
Member: 11571
Thanks Meter: 24
please more details for more help ?
br
tata
Old 04-03-2006, 00:00   #15 (permalink)
Member: 114679
Thanks Meter: 4
Impossible flash Alcatel Exx with "Total Alcatel Commander v1.0"
Read option work 100% but write option "Writing Flash..Error!"
I have test win98/XP
Phone before flash work ok, only flash for change language and remove log operator, but now is dead, not power
Here log:
Start time: 04:49:53 p.m.
Power On phone...OK
Loading Boot...OK.
Reading Hardware info..OK.
Flash ID : 01007E0A
Flash Type : AMD - 4 Mb
Reading Phone info..OK.
Phone Type : ÿÿÿÿÿ
Phone Version : ÿÿÿÿÿÿÿÿÿÿÿÿÿ
Phone IMEI : 010603-00-099476
End time: 04:49:56 p.m.
Start time: 04:50:12 p.m.
Erasing Flash..OK.
End time: 04:50:32 p.m
post all setool problems here taopheek SETool2 85 11-13-2011 15:47
Report All Ust Bugs Here.... manju UST Pro II 11 04-22-2007 14:04
Report All Multibox Bugs Here!!! arsenal Multi-Box 0 04-14-2006 13:20
Page generated in 0.33513 seconds with 10 queries
