LG8130... calculation ok ...but the fone doesn't accept the code !!!! hello i have tried to unlock lg8130 with redbox relocking and then unlocking aal was ok but in pressing :2945#*88110# the fone give no response pls tell me how i can solve this problem ============================================ Power on Phone..OK. Loading header..Accepted. Loading boot..OK. Imei : 3549310057**** Relocking Phone..OK. Power on Phone..OK. Loading header..Accepted. Loading boot..OK. Imei : 3549310057**** Unlocking Phone..OK. Put Simcard to phone and Power on: Press : 2945#*88110# Select lock and use this codes to unlock: NCK : 23126602 NSCK: 34015088 SPCK: 45301120 CCK : 56260215 PCK : 67453346 ESCK: 78342433 ========================================= BR |
i have got the same problem with another fone pls tell me if anyone can help me BR |
vers.106+ downgrade..................first:) |
correct you will have to downgrade the phone then re upgrade once you have entered the codes. If you are using Vygis toolbox this is very easy . be careful when you downgrade as you can kill your phone in one button press. br filipas Ps greetings to my friend Megone |
what is the method to check version..? it calculate the code ok ..... but just to entr the code i'll have to use some other box???? BR |
hi, I have same problem with u8120 ver105.any other method with out downgrade. regards santhosh_vk |
is there any solution with redbox ??? |
The only way to unlock 8130 106+ is to downgreat first then unlock !!! |
how you get the spck code? |
what can i write here coz Respected Yashaka are my teacher in GSM . BR Kashif Khan |
The method of sw is that the codes that you see was not readed from phone was writed in phone! ;) In fact it is posible that sw can done ok but the sec.area was not writed succesfully and you can't enter those codes because was not writed in phone ;) best regards vali |
if no response at unlock menu downgrade first and then enter unlock code best regards vali |
i think now phone pass his half life................................. |
cruiser did not boot lg8130 pls help me thanks |
