Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SwS Team Products > Redbox
Old 08-19-2005, 17:39   #1 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
Redbox New Update With Big Bug
tHIS IS THE PROBLEM WITH PHILLIP 755
Power ON Phone...OK!
TAT MODE..OK!
Reading Imei..OK!
IMEI : 352751-00-016507 8
Reading Codes..OK!
NCK : ********OPEN*******
NSCK : ********OPEN*******
SPCK : ********OPEN*******
CCK : ********OPEN*******
Reading Lang Pack..
Communication Error !!
Set to Default ...Error!
Reading Imei..
Remove your battery and put SIM CARD than Enter New Code manually.
Power ON Phone...Error!
Loading Boot......Error!
File Size : 8388608 Byte(s).
Loading Boot........OK!
Flash ID : 2010
Type : ST M58WR064B 8Mo
PHILIPS PRODUCT : KMELEON
i FLASHED IT WITH REPAIR FLASH BUT COULD NOT GET THE ie
NCK 524c412ei
i had set the defauly still the seem and tried to click on open codes but seem
with flash it finished well but seem problem i did all prossible mine but in vien
Old 08-19-2005, 18:45   #2 (permalink)
julvir's Avatar
Member: 3173
Sonork: 100.100
Thanks Meter: 17,098
Arrow
Flash it , then set to defaults , then read code ( dont open lock ) and enter code manual
Old 08-20-2005, 12:29   #3 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
Please we dont have flash files for 755 in the support area unless we use diffrent model please help
Old 09-29-2006, 12:24   #4 (permalink)
Member: 4527
Thanks Meter: 40
yep. No flash and no suppor for this old model It can't be unlocked still. Always errors with any cable. Only TAT mode and imei can be shown.
New update and ufs bug fix ..::Rizwan::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 02-13-2010 23:32
why you make new update with read codes Mounir ULT PRO 0 01-12-2008 17:03
when new update with M610 come Mounir UST Pro II 0 11-04-2007 21:16
Smart-Clip New Update with Problem Afzaal Motorola P2k 2 11-27-2005 13:22
new update with bug!!! :::GsmFather::: Redbox 3 08-19-2005 18:40
Page generated in 0.12936 seconds with 9 queries
