I have same problem X1-Trio stop 40% .. Soldering test point full charge battery every time stops 40% ... Please help me how solved this problem . Kotogsm |
TIP Better to remove LCD. Better to keep ON your internet connection. Then open the latest soft. Select model - check direct unlock. Connect cable - then TP adapter. {if u use an EXTENSION cable from your PC LPT port - if should be short in length AND OK in nature & quality} Turn ON the phone and as soon as u see the LEDs are glown PRESS immediately the unlock button. IF soft asks to "remove battery and put it back and press ok " - do that carefully. Make sure your TP adapter / wirings doesnt get disturbed during removal of battery. NOW.. Here again the same way - press "OK" as the LEDs are litted. ps: USE ms-word to view TXT file instead of Notepad.exe. [stating colors and pin numbers] :) In any case battery must be nicely charged. |
hello all when connecting to update client I get this message Reset Key...OK. Connecting to server... OK!!! Asking server for access...OK. Asking server for Update...Error but i try to launch soft for unlock phone i have message key not found need solution urgently and thanks in advance |
Reset Key...OK. Connecting to server... OK!!! Asking server for access...OK. Asking server for Update...OK. Updating Key Plz wait...Error!! Try Again ! hehe i post my problem here too and hope someone to tell me what to do :) |
if it was updated i thing it dont gives me error "key not found" for all versions. my bios settings is ok |
I have proble unlocking My x1tro I connect the box and adapter with the phone on when put theunlock cable my phone automaticlly switch off :confused: I use conector MY x5=x3 and i choose in soft My x1 Any help |
Sagem cable solution by Albelektronik.com Hi all, If You have cable problem do this modification........ http://80.188.234.147:21080/ Click on PRODUCT section, Click on Cable section and see scheme Regards;Olsi-Albania Albelektronik TEAM [email protected] |
Per Unlocker AL Po hajde o Enis deri te Albelektronik pse lodhesh ne forum me te shkruar :) Hajd se e bera x1 tende, dhe kabllin e modifikova, ne rregull punon, Ciao OLSI |
Hello ALL! this is solution: www.albelektronik.com click in PRODUCT section and get a scheme how to modyfy cable Regards;Olsi www.albelektronik.com [email protected] +355682227568 |
Sagem cable solution -------------------------------------------------------------------------------- Hello ALL! this is solution: www.albelektronik.com click in PRODUCT section and get a scheme how to modyfy cable Regards;Olsi www.albelektronik.com [email protected] +355682227568 |
hey my pro is phone not found. pls help me. before i have unlock 28 phone now phone not found. I check cable and all is ok. need pinout for c2 |
i have a same problem with server Reset Key...OK. Connecting to server... OK!!! Asking server for access...OK. Asking server for Update...Error pls help best regart senkron24 |
was it just posted for a merely a publicity??? IF not post the correct link. |
