10-25-2005, 16:01 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | why SWS-SAG can not unlock the serie of with test point as X1,X3,X5,X2-2? Thus, If there is a clever one who can tell us how to do step by step please help, nor Julvir and other people could support us for 3-4 moths even I am shouting many times for this subject! SWS support is very BAD! but hope a good man will come and tell us how to unlock mantioned models with SWS-SAG. because we lost our hope from SWS team. Regards Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5586740329110 JA3,LE: 170605 1432 - Phone Imei: 355745004537842 - Hash Table : 03 18 01 - Phone Code : 00000000 |
10-25-2005, 20:03 | #2 (permalink) |
Freak Poster Join Date: Apr 2003
Member: 25759 Status: Offline Thanks Meter: 159 | may be the problem is in your test point adapter as x1 x3 x5 use the same adapter i have unlocked nearly 50 pcs x1 without any problem thou sometimes u have to connect the phone 5 to 6 times |
10-26-2005, 11:19 | #4 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 52
Member: 3617 Status: Offline Thanks Meter: 583 | the same problem happen to me, I bought another cable from Jtag box and the same thing,i can t unlock series X1,X1 trio ect Maybe we have problem with testpoint adapter |
10-27-2005, 19:12 | #6 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | jerrykaka If you think the test points are problem; with the same test points I could unlock X5 with SCDR1.4 there was not any problem, and if you have correct test points can youpost them and explain how to do? hitibiti I am using this cable also for V55, but there is not any problem! I don't think that there is cable problem! Multi-COM I also touched the PCB and test pionts with finger as do for C4. I tested all possible things. But still could not unlock any one of these models. Still have the problem, nobody could say a valid way for that problem.. |
10-27-2005, 23:55 | #7 (permalink) |
Freak Poster Join Date: Jun 2002 Location: TUNISIA Age: 53
Member: 12550 Status: Offline Thanks Meter: 1 | I have problem too with x2-2 always bad connection even if i solder the test points (but it is true i was touching the pcb with fingers!), for x1trio no problem all were done via server+++, and i never used my dongle for old sag like x1,x5,x5m because i have un old scr1. BR |
10-28-2005, 00:47 | #8 (permalink) |
Freak Poster Join Date: Jun 2005
Member: 150790 Status: Offline Thanks Meter: 2 | I also had problems connecting a few MY_X3 phones using SWS-SAG. When it finally did I got wrong codes, direct unlock killed the first one I tried. An old SCR 1 gave me correct codes for the rest. Is there any chance of reviving the dead one ??? |
10-28-2005, 03:02 | #9 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 201 | are SCDRII adapters compatible with sws-sagem!? hi i got sws-sagem dongle last week, in the package i found 11 adapters with tikets SCDRII. are this adapters compatible with SWS-SAGEM, cause i have seen the pinouts tp in the pictures from the support area, and i test the mine in the adapters, they aren't the same!!! today i was trying to unlock sagem x1, but always "phone not found" where is my probleme? thanks |
10-28-2005, 03:55 | #11 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 201 | thanks for confirming me but tell me, i'm testing all the pinout of my adapters now, to compare them with the images in the support. so i found that they're all the same, but the myx-5 adapter aren't!! in the image i found from up to doun : .pin6 .pin3 .pin2 .pin7 but in the adapter: .pin2 .pin3 .pin7 .pin6 so, they are differente and i think that's why i can't unlock an x1 |
10-28-2005, 11:25 | #13 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | Friend! This is not adapter problem, I am also soldering cable to test points everytime! I have never used ADAPTER! But anyway can not unlock any of these models which has test points with x1.. Julvir is still sleeping! Have a nice dream! |
10-28-2005, 15:14 | #15 (permalink) |
Junior Member Join Date: Nov 2004 Age: 41
Member: 91409 Status: Offline Thanks Meter: 1 | sws testpoint when u connect the test point adapters you must power on the phones in order for you to the read the codes put in a simcard that the phones doesn't accept and enter the high code you should be o.k |
i can not use the last update with my ufs2 without HWK... why?? | tsarkh | UFS2 + UFS3-Tornadoflasher | 1 | 02-18-2007 14:56 |
Why Bird S1160 Can Not Unlock In Multibox? | zonetrichur | Multi-Box | 5 | 09-28-2006 09:04 |
what happen SwS-Sag box,used display BAD CONNECTION CHECK YOUR TEST POINT!!! | kkio | SwS_SaG_BoX | 24 | 05-15-2006 12:13 |
