03-12-2006, 15:53 | #1 (permalink) |
Banned Join Date: May 2005 Age: 41
Member: 146308 Status: Offline Thanks Meter: 30 | what happen SwS-Sag box,used display BAD CONNECTION CHECK YOUR TEST POINT!!! can any one post a detail here make it step by step since i got the box i never beable unlock these 3 model.. |
04-11-2006, 08:58 | #11 (permalink) |
No Life Poster Join Date: Jun 2003 Location: gods on country(kerala)
Member: 31906 Status: Offline Thanks Meter: 101 | Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Firmware : 5110411532262 KE3,UD: 211105 1322 - Phone Imei: 355872005005031 - Hash Table : AC 60 01 - Phone Code : 0000 |
04-12-2006, 08:38 | #14 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 42
Member: 84694 Status: Offline Thanks Meter: 9 | kkio is right.sws has some bugs in the models he has mentioned eg:myc3-2.i have unlocked many sagems using sws but i never succeeded in myc3-2.i tried all the tricks but still no luck. |
04-12-2006, 10:00 | #15 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2005 Location: Iclouds
Member: 142219 Status: Offline Sonork: 100.107814, Thanks Meter: 368 | please short pin no eight of your sws doungle to mobile ground ,every time you unlock any phone with sws-sag. with this trick you can unlock every phone in first try. tested hunderd times!!! br mobilecraker |
SwS-Sag-Box Bad Connection Check Your Test Point | Seedy | SwS_SaG_BoX | 5 | 04-29-2006 15:11 |
Bad Connection Check Your Test Point!!! | sewkar | SwS_SaG_BoX | 40 | 04-12-2006 18:40 |
myx7.. bad connection check your test point | CHAPRAN | Redbox | 3 | 02-23-2006 08:12 |
MYC2-3 always " BAD CONNECTION CHECK YOUR TEST POINT!!!" | CyberKareca | Redbox | 8 | 12-25-2005 11:35 |
Bad Connection Check Your Test Point | .:bono:. | Redbox | 0 | 12-21-2005 02:27 |
